Old 09-20-2017, 05:16 PM   #1
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Nail in my run flat tire.
Well Damn....nail in my tire within 1 month of ownership. I remember when I had my Vette and run flats were not repairable. I pulled the nail and sure enough, air started spewing out. Called my local discount tire just to see if it was possible to repair, he said that in the last 8 months that they now can repair them, apparently there is some new material that will fix run flats. So.. had it plugged, hopefully won’t have any issues with it.
1hprush is offline   Reply With Quote
Old 09-20-2017, 05:38 PM   #2
1sspat
Tampa Gulf Coast Family
1sspat's Avatar
Drives: 2016 2SS, 6SP, NPP, MRC, NAV
Tell us know if you have any issues in the future. Also where in the tire did you get the nail?
1sspat is offline   Reply With Quote
Old 09-20-2017, 05:41 PM   #3
Rustydaytons
Drives: Chevy
Didn't buy the tire and wheel warranty?
Rustydaytons is offline   Reply With Quote
Old 09-20-2017, 06:18 PM   #4
TJay74
Dont know where you found that run flats are not repairable. Goodyear and Michelin both approve of repairing run flat tires as long as the object is not in the outer treadblock zone of the tire.
Old 09-20-2017, 06:33 PM   #5
1hprush
2018 ZL1 1LE
1hprush's Avatar
Right rear, inner side of the tire, about 3/4" from inner side wall.
Nah...never buy the warranty. Plan on storing the car in a month and in the spring I will buy new rims and tires. These tires won't see the car again
until I sell it. Hope that plug is still intact by then.
Good to know. All I could see when I saw the nail was $$$. Discount said they have only been plugging run flats for less than a year. The last time I ran run flats, they were not repairable.
Old 09-20-2017, 07:13 PM   #6
nascarazy
nascarazy's Avatar
Drives: '18 ZL1 & '17 2500HD Midnight Ed
You're lucky. Picking up a bolt on the interstate did this and cost me a tire.
2018 Camaro ZL1 - Garnet Red Tintcoat[/B]
- Order Placed@ dealership 8/12/2017
- 1100 8/21/2017
- 3100 8/23/2017 (TPW 9/11)
- 3400 8/25/2017
- 4300 9/11/2017 (VIN available)
- 4200 9/15/2017
- 4200 9/20/2017 (on train near North Platte, NE)
- 4200 9/22/2017
- 4200 9/23/2017 (car in town)
- 5000 9/25/2017
- 6000 9/26/2017 (Finally in our garage!)
nascarazy is offline   Reply With Quote
Old 09-20-2017, 08:22 PM   #7
Erin2017RS
Drives: 2017 RS
Picked up a screw after I turned over 500 miles. I limped it to a Firestone because it was closest to work and they wouldn't patch it. Funny, bc the kid told me the only repairable run flats were bridgestones. I never researched it so i dont know how true that is. Wish I had the tire an wheel warranty. Had it on my bmw for 5 years and never used it. 2 weeks into my camaro and the screw happened.
Erin2017RS is offline   Reply With Quote
Old 09-20-2017, 09:01 PM   #8
Rustydaytons
Drives: Chevy
The tire warranty is actually a good thing if you read into it. And I'm one to never buy gimick warranties....
Old 09-21-2017, 12:45 AM   #9
WVaSS
WVaSS's Avatar
Drives: 2016 Nightfall Grey 2SS M6
Plugged mine on the side of the road. Over 2,000 miles no problem. Don't buy that "you can't repair run flat tires". That's just BS to sell tires.
WVaSS is offline   Reply With Quote
Old 09-21-2017, 09:47 AM   #10
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
I have had three tires replaced and one repaired in two years of ownership. Only one original tire left on the car. I thank GM for using run flats since I don't have to worry if I do pick up a road hazard. Every flat was caused by a nail/screw. Too much home building in this area, I guess.
Old 09-21-2017, 11:28 AM   #11
SSport16
SSport16's Avatar
As long as it is not too close to the sidewall, then they can fix it. Mine had to be replaced, was right near the edge of the tire/sidewall.
Old 09-21-2017, 01:55 PM   #12
whiteboyblues2001
whiteboyblues2001's Avatar
So if these run flats are repairable, would it be wise to go to an HPDE track day after one of the original run flat tires has been plugged?
whiteboyblues2001 is offline   Reply With Quote
Old 09-22-2017, 01:14 AM   #13
Josh The People
Josh The People's Avatar
Drives: TT 10' SS -> 16' SS
Picked up a nail earlier this summer. Used a cheap plug type kit $10. No problems 3k later and lots of aggressive driving.
Josh The People is offline   Reply With Quote
Old 09-22-2017, 08:19 AM   #14
1hprush
2018 ZL1 1LE
1hprush's Avatar
What are you guys using to plug the tire with? Are you removing it? They actually removed my tire from the rim to fix it.
