Old 09-12-2017, 09:56 PM   #1
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
No Lift Shift with FI?
When I was NA I managed to get the NLS down and it was quite a blast to use it on occasion. Since the procharger I've never had the nerve to try it again and was just curious if people feel it's not recommended or higher risk of things going wrong quicker under boost, etc.
Who's tried it?
Dysan911 is offline   Reply With Quote
Old 09-13-2017, 12:06 PM   #2
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
d1sc and meth, I've done it, but Not sure how well it does with methanol. It would depend on what vacuum does under that circumstance. I imagine a shut bypass valve, confused methanol system, and not enough fuel would be dangerous lol
exxit is offline   Reply With Quote
Old 09-13-2017, 02:26 PM   #3
PackersFan26
PackersFan26's Avatar
Drives: 2017 Summit White 2SS
I would be careful with the NLS with high HP situations. I can see shit breaking very quickly lol.
Follow me on IG: @lip_stick.ss
PackersFan26 is offline   Reply With Quote
Old 09-13-2017, 03:21 PM   #4
Dysan911
Dysan911's Avatar
That's kinda what I was thinking. I remember when I was learning to do it the first few times were rough. With the extra power you're right. One tiny mistake results in breaking stuff for sure.
Old 09-13-2017, 05:57 PM   #5
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
I've used it...I've also disabled it. I don't like the timing pull/ramp when I shift, especially under Boost when I'm shifting hard. Ironically, if you shift fast enough, NLS doesn't do anything helpful anyway.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
