Old 09-09-2017, 09:57 AM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Rear Differential fluid change today.
I am going to change the rear differential fluid today. Manual says 1.6 qts so I purchased 3 from Amazon. GM LS gear oil 88862624. Ordered them prime yesterday at 3pm and they were on my doorstep early this morning.
Old 09-09-2017, 10:00 AM   #2
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
no additive?
Old 09-09-2017, 10:03 AM   #3
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
no additive?
That fluid has the additive in it.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 09-09-2017, 10:04 AM   #4
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Ah ty.. I had been using the redline with the additive.. never thought of going that way!
Old 09-09-2017, 11:27 AM   #5
Risky Justice
Risky Justice's Avatar
Drives: 2016 Camaro 2SS M6
Make sure you have a fluid transfer pump, or whatever you want to call it, on hand. You're not going to get that bottle or a funnel anywhere near the fill hole (if it is anything like the SS). I just filled it until it ran out the fill hole, but based on what is left in the 2nd bottle...1.6 quarts is probably about spot on.
‘16 Camaro 2SS M6 - RotoFab CAI, Soler Performance TB, E85
8.102 @ 89.85 MPH (bone stock)
Risky Justice is offline   Reply With Quote
Old 09-09-2017, 11:41 AM   #6
WhyUMad1LE
Drives: 17 SS 1LE
Why did you purchase 3? 64 oz = 2 qt.
Old 09-09-2017, 11:44 AM   #7
Biscuit.fr
Drives: Red hot ZL1 A10 2017
1 bootle and 1/2
about 1.3 L
esay to do
Biscuit.fr is offline   Reply With Quote
Old 09-09-2017, 12:00 PM   #8
Stephen12ZL1
Drives: '21 ZLE A10
Because I have learned not to trust certain capacities. I didn't want to be stuck without enough fluid.
Old 09-10-2017, 01:33 PM   #9
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Finished mine a little while ago. was pretty easy.
nancygrl is offline   Reply With Quote
Old 10-01-2017, 01:25 PM   #10
Stephen12ZL1
Drives: '21 ZLE A10
I forgot to post about this fluid change. It is the easiest fluid change possible. Anyone that pays the dealer $100 to perform this task must not be able to change a lightbulb. Once you get under the car, the drain is staring you in the face on the differential. Use a 3/8” socket extension or the 3/8” socket wrench to loosen the drain plug. The fill is on the driver’s side and a transfer pump is not necessary. You can put a nipple with a small section of rubber hose and squeeze the bottle. The drained fluid looked much better than the previous Gen 5 ZL1 at 1500 miles. No metal on the plug magnet either. The capacity is correct at 1.5-1.6 qts.
Old 10-01-2017, 01:54 PM   #11
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Dealer wanted almost 300 to change mine lol, did it myself in 15 minutes. Like you op I got the gm recommended fluid on amazon lol.
soloknight6 is offline   Reply With Quote
Old 10-01-2017, 03:38 PM   #12
Stephen12ZL1
Drives: '21 ZLE A10
$300!!!! Stealership!!
Old 10-02-2017, 05:40 AM   #13
SliChillax
SliChillax's Avatar
Drives: Camaro ZL1 A10, F-Type R, RR Sport
Nice to see a Mass Effect fan on this forum lol
SliChillax is offline   Reply With Quote
Old 10-02-2017, 08:22 AM   #14
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
Changed my diff , and manual trans fluid myself over the weekend too. Piece of cake for both.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
