Old 09-05-2017, 11:04 AM   #1
1LEMATT
1LE enthusiast
1LEMATT's Avatar
Drives: 2017 SS 1LE
Slight rumble/vibration in 3rd gear around 3500 under harder acceleration?
I notice a slight vibration, that feels like a rumble sensation, when I am accelerating a little harder in 3rd gear. It seems to happen at around 3500 rpm, and only lasts for a few seconds. It's pretty minor, but I can notice it, and it is pretty much just under that type of situation. If I am below or above that range, it doesn't do it. I just worry something may be loose or not right even though my dealer says "everything is normal". Does anyone else notice this?
2017 SS 1LE
1LEMATT is offline   Reply With Quote
Old 09-05-2017, 11:28 AM   #2
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
I have the same issue but not as brief as you. It'll do it the whole time I'm getting on the gas under heavy acceleration in 3rd gear, same rpm... feels like a harmonic balance issue or something. Shakes the whole car. I kinda hate it.
Bad Anvil Garage is offline   Reply With Quote
Old 09-05-2017, 11:39 AM   #3
1LEMATT
1LE enthusiast
1LEMATT's Avatar
Drives: 2017 SS 1LE
I may have underestimated the time, it can be more than a second depending on the situation...interesting you seem to feel it too though. I edited my OP.
2017 SS 1LE
Old 09-05-2017, 01:13 PM   #4
The_Coleman
Drives: 2017 NGM 1SS 1LE
I noticed the same in third and to a lesser extent in fourth. Its not as severe for me as it sounds like for you. I tend to drive my car hard though so I'm often going down a gear at that RPM and then accelerating.
There have been other threads on this, but no root cause determined.
The_Coleman is offline   Reply With Quote
Old 09-05-2017, 02:00 PM   #5
Bad Anvil Garage
Originally Posted by The_Coleman View Post
I noticed the same in third and to a lesser extent in fourth...
...There have been other threads on this, but no root cause determined.
Yes, fourth too... a little less noticeable but there. I've also read that others have the same issue and are calling it normal. Maybe so, but I'd really like to know WHY?
Old 09-05-2017, 02:03 PM   #6
AZ_1LE
Drives: 2019 ZL1 1LE
Drive train harmonics combined with either too loose or too stiff transmission and engine mounts.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 09-05-2017, 02:10 PM   #7
Bad Anvil Garage
And this is harmless?
Old 09-05-2017, 02:20 PM   #8
AZ_1LE
It's bound to wear out the mounts some, but that's probably about it. I am sort of waiting for an aftermarket company to figure it out and release new mounts to eliminate the issue. Might also help with drivetrain slop on/off throttle.
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 09-05-2017, 04:48 PM   #9
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
So you seem to think it is definitely the mounts huh? I was almost thinking it was some sort of exhaust resonance. But, if it does end up being the type of mounts being used, I would be all for an upgrade. Just not sure how we prove this until someone does the swap and compares. I just wonder if the OEM ones are too soft, or too hard. You would assume soft, but I would think that a hard one would be more prone to giving off those vibs? Also, curious if this is the case, if it is all of them, or just motor mounts, or just the trans mount...
Also seems to be on all SS's not just SS 1LE's as in the Motor Trend Head to Head with the SS vs M4 they mention some sort of NVH issue around 4000 rpm if I recall. They actually liked it though lol...for real.
Old 09-06-2017, 08:37 AM   #10
1LEMATT
1LE enthusiast
1LEMATT's Avatar
Drives: 2017 SS 1LE
So I asked on the Facebook group, and others say they can feel the same thing...
Can anybody else in here confirm they do infact feel this too?
I am thinking taking it to another dealer may be a waste of my time if this is infact "normal".
2017 SS 1LE
Old 09-07-2017, 08:17 AM   #11
1LEMATT
1LE enthusiast
1LEMATT's Avatar
Drives: 2017 SS 1LE
Guess nobody else has any input on this?
Does anybody else feel this like us above?
Trying to decide if I should have another dealer look at it or not...thx
2017 SS 1LE
Old 09-07-2017, 12:15 PM   #12
Tim202
Drives: 2018 ZL1 1LE
I feel it, but I thought I was too hard on the gas and spinning the rears. Now I am thinking not.
Tim202 is offline   Reply With Quote
Old 09-07-2017, 12:55 PM   #13
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
If you are spinning the tires in 3rd gear at 3500 rpm you must have quite a beast!
It definitely doesn't feel like wheel spin to me. It almost feels like a slight rumbling for a bit.
Old 09-07-2017, 03:14 PM   #14
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
I have it as well, 3rd and 4th gear from around 3-4k. Just feels like drivetrain resonance to me, most likely driveshaft vibration. I don't think any harm will come of it.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
