Old 09-01-2017, 03:26 AM   #1
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
What would it take to sound like this?
Appears to be a newer CLA45 AMG. Merc really has the exhaust sound figured out on their 2.0t! Sounds like someone is snapping a baseball bat on upshifts, and downshifts sound completely amazeballs.
https://youtu.be/HwIhotj2cWc
ChicagoTommy is offline   Reply With Quote
Old 09-01-2017, 10:17 AM   #2
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Holy smokes... Sounds almost like a catless, straight pipe with a muffler delete but the sound is being tuned somehow to make sex in my earholes.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 09-01-2017, 11:06 AM   #3
Ashium
Drives: Camaro 2.0t, 300zx TT, LSTT Mustang
Like I've said before the stock SRT4's sound pretty dam good and they pretty much just had cats and resonators. Someone should try adding a resonator or 2.
Ashium is offline   Reply With Quote
Old 09-01-2017, 05:26 PM   #4
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
for fun... Lets look at the differences we know about the M133, and the LTG
Bore / Stroke
LTG= 86mm / 86mm
M133 = 83mm / 92mm
Could the longer stroke have something to do with the sound?
Compression ratio
LTG = 9.5:1
M133 = 8.6:1
Max engine speed:
LTG = 7000
M133 = 6700
Both have a twin scroll turbo, the M133 sees about 26psi of boost stock, the LTG typically 18-20
the amg his a similar looking suitcase muffler to the Camaro and ATS, but it's about 50% smaller looking. The exhaust has some sort of magical flap that varies in position with throttle position and engine load (*cough* variable back pressure down pipe sound familiar? *cough*)... Looks to have just a single 12" or so bullet resonator under about the drivers seat.
Can't find anything that tells me the firing order, to see if its any different, cam specs or anything else... I read an article that says it cuts injection and ignition during hard upshifts to give it that sound.
Great sound! Would be nice.
Old 09-02-2017, 11:01 AM   #5
b0bsaget007
b0bsaget007's Avatar
Drives: 2016 2LT RS Blue Velvet
This CLA45 is indeed modified. The parts list is in the description of the video. Intake, catless dp, exhaust system (probably without mufflers) are the main noise makers.
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD
Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake
b0bsaget007 is offline   Reply With Quote
Old 09-02-2017, 01:45 PM   #6
SoCalThug
Drives: 2012 Summit White 1Ls
i think the mod list are the mods for his wrx not the cla. the cla does sound modded though
SoCalThug is offline   Reply With Quote
Old 09-03-2017, 02:31 PM   #7
ChicagoTommy
Yeah, it looks like the mod list is for this guy's WRX.
Jason, I was thinking along the same lines as you. I'd bet that the right cam specs could make it happen.
I'd love to get my hands on a stock tune file for a CLA45. Just to see how they are getting the upshift crack.
Old 09-03-2017, 09:13 PM   #8
DatsunBob
Drives: ATS 2.0t Rwd Performance
Sounds like some sort of ignition cut
DatsunBob is offline   Reply With Quote
Old 09-11-2017, 05:22 PM   #9
vaspen
vaspen's Avatar
Drives: 2017 l4 blue 6speed
yall notice how much faster that downrevs than our cars ? j.s .... that may be why it has that pop but that exhaust isn't stock it you look at the beginning
vaspen is offline   Reply With Quote
Old 09-11-2017, 06:03 PM   #10
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
That's what 400 + HP sounds like being squeezed out of a 2.0
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 09-11-2017, 11:58 PM   #11
ChicagoTommy
Ugh, between this and the 2.5 turbo in the 718 Porsche, so many good sounding 4 cylinders!
Old 09-14-2017, 05:49 PM   #12
PhantomATS
Drives: 2014 Cadillac ATS 2.0T
Bleh, I like the sound of the ZZP Stage 1 Kit and Borla exhaust more ;-)
https://youtu.be/vAhnL-8rFvI
PhantomATS is offline   Reply With Quote
Old 09-18-2017, 11:54 AM   #13
dekes1
Drives: Camaro like
I'm so glad to read you guys sharing the same desire. Personally, I see too many guys chasing the Honda fart-can sound which is just terrible. The controlled, deeper, muffled-but-not-silent sound, plus the perfect burble and pop during shifts is the stuff 4cylinder legends are made of.
Cut-outs?-for drag racing yes, everywhere else no!
No cats, no muffler, and straight pipe? - for drag racing yes, everywhere else no!
Louder does not mean cooler.
Take a look on YouTube for one of Matt Farrah's OneTake shows where he drives the GLA45 AMG with mods. Slightly loud, but damn near perfect 4cyl sound.
dekes1 is offline   Reply With Quote
Old 09-18-2017, 09:36 PM   #14
Jason@JacFab
Yeah, I've read several times, with increased HP comes the sound, from people trying to deter others from just sound mods like mufflers/deletes/etc.
I bet if someone had a 400+ hp LTG it might sound a lot different than these bolt on specials.
