Old 08-31-2017, 08:22 PM   #1
Frank S 3553
2SS,MRC,NPP,
Magnuson Pump failure?? HELP
i had some fluid leak out of the intercooler reservoir on a magnuson. when i removed the cap it it was 2 to 3 inches low i filled it and worked some air out by pushing on the upper hose. The pump should come on with the key in the run position with the engine off ( i think ) i can't hear the pump runing and i dont see any circulation.
Please help
Frank S 3553 is offline   Reply With Quote
Old 08-31-2017, 08:58 PM   #2
brettman
Drives: 2016 Camaro SS
Start it and Check, Trigger wire plugs into the EVAP.
brettman is offline   Reply With Quote
Old 08-31-2017, 08:58 PM   #3
laynlo15
Drives: 2022 Lt1 A10
I've not had that problem with mine. Call Magnuson and talk to Cindy and she will help you out or get you to the person who can. I've had no problems with mine at all but I want to make sure your taken care of. If you need to you can text me and I can email Cindy and she can get back to you tomorrow.
Old 08-31-2017, 09:00 PM   #4
laynlo15
Also check your connections and see if you see any coolant leaks. Check fuses.
Old 08-31-2017, 09:10 PM   #5
Frank S 3553
2SS,MRC,NPP,
Thanks!! so the EVAP comes on only when the engine is running?
Old 08-31-2017, 09:17 PM   #6
Frank S 3553
2SS,MRC,NPP,
thanks brother!!
Old 08-31-2017, 10:20 PM   #7
brettman
Should be, it's vacuum to purge gas fumes from fuel tank.
If you want to run pump with no power on, pull relay and jumper terminal 30 and 87 with a wire (as long as 15 amp fuse is good) This method is good to bleed system of air (that does take some time)
Hope your pump is good, that's a job to replace.
Old 08-31-2017, 10:56 PM   #8
Frank S 3553
2SS,MRC,NPP,
I will try it running thanks. if there is air in it will the pump not run? where is the pump at? thanks for all the help!!
Old 08-31-2017, 11:22 PM   #9
brettman
Pump will run with air (just sounds weird) I believe your is under the air box (LH side) Whipple (mine) is worst, behind the nose PITA...lol
Old 09-01-2017, 06:03 AM   #10
laynlo15
I sent an email for you to Magnuson to help get your issue resolved. Did you do the install or was it done at a shop?
Old 09-02-2017, 12:03 AM   #11
toohighpsi
Drives: 2015 C7 Z06 M7
If everything was installed correctly it's pretty much impossible for the pump on the Camaro systems to be air bound. There must be something wrong with the pump or the power to it. It will be swirling like mad in that tank when the pump is running.
Old 09-02-2017, 07:04 AM   #12
laynlo15
Thx Mike, glad you chimed in on this issue. Frank talked to Derick yesterday about the pump and hopefully they can get it figured out.
Old 09-03-2017, 06:19 AM   #13
ADM PERFORMANCE
Drives: Anything I want
Keep in mind this pump starts up slow and needs a hand on it once it reaches max speed,if you feel it running it should be flowing.
I agree with mike
ADM PERFORMANCE is offline   Reply With Quote
Old 09-03-2017, 07:37 AM   #14
laynlo15
Agree, you can take the cap off and see the flow of the coolant and you can also hear the pump running with the engine off and in the accy mode.
