Old 08-31-2017, 01:39 PM   #1
parish8
Drives: 17 SS a8
Using paddle shifter as a boost scramble or nitrous activate button
I like as clean and stock appearing interior as possible but often have a lot going on that can't be seen. In this case I wanted an easy to reach boost scramble button. I am using it to switch an input on my stand beside ECM but it could also trigger an input on a separate boost controller or a nitrous controller.
My ECM has the option for 2 boost maps. The first one can be speed, tps or rpm based. The 2nd table is tps and rpm based. They are both closed loop or open loop. I run them closed loop and command a certain kpa. In order to activate the boost 2 table you ground one of the inputs to the ECM.
After digging around in the steering wheel and column I found a purple/yellow wire right in the top of the column that is the paddle shifter output. It reads 6k to ground without pulling the paddle shifter and drops to 600ohms when you pull it. The ECM needs about 400ohms to switch so I added a 600ohm resister to ground off of that wire. Now when I pull it the resistance goes from 600 down to 300ohms and triggers the ECM.
Of course this kills the paddle shifters but I have never used them anyways. So far it is working in the garage. I should get it out for a test drive soon and will report any issues. I may have to put a 6k ohm resistor on the wire that I cut to ground to simulate the paddle shifters. I also put a switch in the council so I can activate boost 2 that way. Here is a crappy video I shot on the dark last night. I will get something better up once I get it all cleaned up.
https://youtu.be/YD561J03se0
Old 08-31-2017, 01:53 PM   #2
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
Very nice, great idea..
Perdieu is offline   Reply With Quote
Old 08-31-2017, 01:55 PM   #3
dennis@hixsonnet.com
Drives: Me: '16 2SS yellow, Wife: '16 1SS
great idea!!!
- Dennis Hixson
2016 Camaro 2SS ** EdelBrock E-Force Supercharger, 3" pulley, RotoFab air intake, Alky Methanol Injection System, Corsa Extreme Exhaust, Kooks longtube headers, TSP VV2 CAM, 1LE wheels @ 285/30/20 front & 305/30/20 rear... 707.41rwhp, 702.36 torque
dennis@hixsonnet.com is offline   Reply With Quote
Old 08-31-2017, 02:21 PM   #4
Omega
Drives: G8
Hmm. This would be great for me except I don't have the paddle shifters. Could I add this in an M6 car?
This is my current solution:
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 08-31-2017, 02:39 PM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I like it!!
Old 08-31-2017, 09:04 PM   #6
laynlo15
Drives: 2022 Lt1 A10
Parish, do you sleep? WTF, some of the shit you come up with is amazing. Nice.
Old 08-31-2017, 09:11 PM   #7
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
Damn man, nice work. Makes me feel like crap for not doing more legwork. F it lathe, mill, tig, powerprobe here I come!
Turbo_RORO is offline   Reply With Quote
Old 08-31-2017, 10:04 PM   #8
parish8
Drives: 17 SS a8
Thanks. I am really excited about the stealth boost scramble button but you never know what people around here will like.
Old 09-02-2017, 12:02 AM   #9
JaxChris
Someone give this man a left control pad from a 2SS wheel so he can use the "heater" button. =)~
