![]() Drives: 2018 1SS/Nightfall Gray/M6/NPP Join Date: Aug 2017
How big can i go in the rears on a 1SS? Without any modifications!
Car is being picked up next week! Want to order some tires
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
I think sledgehammer got 315/30 on the rear. I got to look for the thread.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
Soleil
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS, 2010 Camaro SS Join Date: Apr 2012
We have 305/35/20's on our shop car. Ours is a 2016 SS and we had to make a small modification of a wire harness thats in the fender well but it looks like you have a 2018 so the modification has already been done to your car by GM. So you should be able to fit the 305/35/20 just fine.
@salesPhastek,
I think the 305/35 are not matching the wheel circumstance. See ABS/Parking sensor lights on after new wheels?
Soleil
#7 | |
#8 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The rear body is the same as the ZL1 1LE, therefore:
19x12" et41 with 325/30-19 is an OEM fitment, though FYI they stick out quite prominently even with track-levels of negative camber. Oh, you never said why you want bigger rear tires? I'm guessing drag since you didn't mention fronts too.
#9 | |
![]() Drives: 2017 Camaro SS M6 Join Date: Apr 2017
#10 | |
#11 |
You have to keep the tire height within 3/4 of inch difference front to back or the ABS system acts up. Also not all tires are the same height even though they are rated the same. For instance a Nitto NT-555r 305-35-20 is 29" tall where a BF Goodrich comp TA is like 28". The factory Goodyear run flat 245-40-20 is 27.7" tall for reference.
#12 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
#13 |
Black lightning
Couldnt you just get 3/5 MM wheel spacers and not worry about the wire
[ 2021 Camaro ZLE 10 speed
#14 |
