Old 08-30-2017, 08:14 AM   #1
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Anyone connected Aeroforce Wideband to HPTuners?
I've got a wideband setup on my car via my Aeroforce Gauge. It's a Bosch LSU 4.9 sensor running through the aeroforce control box. Has anyone connected this to the HPTuners handheld? From what I read I add a split to the 5v analog signal wire over to my HPTuners. Just wanted to see if anyone has been there done that yet.
Thanks!
Dysan911 is offline   Reply With Quote
Old 09-02-2017, 08:29 AM   #2
Dysan911
Dysan911's Avatar
Just for future reference in case anyone ever does need this info.
Tap 2 wires into the Analog OUT cable from the Aeroforce Wideband control box. It says "Analog Out" and has a 3 wire harness plugged into it. Brown wire is the 5v Signal that goes to the HPTuners Aux Input 1. and the Black wire goes to the HPTuners #5 connector (Ground).
Also disconnect the aeroforce gauge from its harness completely. It will throw off o2 readings if you don't.
Old 09-10-2017, 08:52 AM   #3
Hyperlinkblue
Drives: 2017 1ss m6. Blue.....
I have just a aero force and im looking at adding a wideband since im on e85. So are you refering to the hptuners gauge pod or the actual hookup that goes tovthe labtop?
Hyperlinkblue is offline   Reply With Quote
Old 09-10-2017, 08:58 AM   #4
Dysan911
Dysan911's Avatar
The actual hookup that goes to the laptop. I did figure it out though. See my post right above yours.
Old 09-19-2017, 12:53 PM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
Great info thanks for sharing.
www.jannettyracing.com
email tedj@jannettyracing.com
