![]() Drives: Sold Join Date: Sep 2016
How to remove shark fin antenna?
Anyone know how to remove it?
I want to paint on my antenna but I don't know how to take it off. |
![]() Drives: Fuqing car Join Date: Jul 2017
Pretty sure it's just 3m double sided taped on. Not sure where the actual plug is the though. Probably have to remove the headliner to gain complete access.
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
It's a pretty big job to remove these. The headliner has to be removed, and according to GM docs, the windshield must be removed in order to get the headliner out of the way enough to gain access to the antenna.
#4 | |
Pull up Cougar!
Drives: 2016 2SS Join Date: Jul 2011
OP, probably best to just have it vinyl wrapped. |
Wow, sounds like lots of works.
Thank you for the all reply! |
BYND GARAGE
Drives: 17' 1LT Turbo Join Date: Feb 2016
Not true.. my buddy and I did it before we wrapped his roof. It's fairly simple, just drop the rear headliner and unscrew the antenna from under
#7 | |
SABIO
This. Tight squeeze in the back. But doable.
#8 |
Clay Sculptor at GM
Drives: 2016 Camaro 2SS, M6, MRC, NPP Join Date: Sep 2015
Yes did the same when I wrapped my roof and a friends. Interior b and c pillar panels need removed then the headliner can be lowered in the rear. Then disconnect the wires leading to it and unscrew the nut (7mm I think) then it pops out. It doesn't have 3M tape holding it down, just a small seal.
It is a tight squeeze but I found removing the folding section of the rear seat gives you a little extra room, just watch out for the latch. And be careful to not pull the headliner to hard, it can crease.
Anything I post or say is purely my personal opinion and not a reflection of GM.
#9 | |
#10 |
Clay Sculptor at GM
#11 |
![]() Drives: 2018 Summit White ZL1 Join Date: Dec 2017
Hi Folks, Just did this today, couple of things worth noting - Bolt is 10mm, two connectors are wrapped nicely by the good people in Lansing, so that has to be unwound to get to the connector release. The square plastic mount on the bottom does come out through the roof, just wiggle a bit whilst some one pulls from the top.
Thanks for the good start, with out this post I wasn't sure how this was going to go! Oh, and you were right about that latch!!!
#12 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Has anyone relocated the fin inside the car on the back glass?
#13 |
![]() Drives: 2018 Hot Wheels Edition 2SS Join Date: Jan 2014
How do you physically remove it? The adhesive holding it in place, not the plug. Heat? Mine looks a little off... not perfectly straight from factory. Can it be moved (slightly) without destroying the adhesive? Anyone know?
2018 Hot Wheels Edition 2SS #1581
2014 2SS/RS Red Rock Metallic 2008 Saturn Sky Redline Bluestone |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
how big of a hole is in the roof. im putting a cb in the car I have a nice black roof mount antenna. people are going to think my black SS is a police car. I dont need the xm and would be nice if i could put the car back to stock with out any holes in it if i was to sell it. the mount is 3/4" but i could get a 3/8" one.
