Old 08-29-2017, 06:28 PM   #1
Giri
Soon to be Millionaire
Drives: Blue 2016 Camaro
Change Differential Fluid on 4cylinder?
Hi Guys,
I'm about to hit 25k miles and was wondering if I should change the differential fluid myself? I have the automatic and 4 cylinder LTG engine.
I do not track my car.
I've been doing oil changes on my own and had two questions:
1- How hard is it to change compared to oil?
2- What are the benefits of changing now vs at 45k miles like the service guide calls for?
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look
Giri is offline   Reply With Quote
Old 08-30-2017, 06:51 AM   #2
EagleRS
EagleRS's Avatar
Drives: Nightfall Grey 2.0L Turbo
It's never too early....
I woudn't wait until 45K miles if you are beating the car on back roads and getting "4 mpg" on back roads. I changed mine at 37K miles and it was nice and black!
It's not difficult what so ever, if you have a way of putting the car on ramps then great, if not, you can lift it from the bump bar that is located right behind the differential.
There is a video somewhere on here that shows a guy changing his fluid on his 1SS, same exact concept just different fluid spec. and capacity. Rule of thumb is pump enough in there until it starts to drip out.
Let me know if you have any questions about it, it's a simple fun task to do....
EagleRS is offline   Reply With Quote
Old 08-30-2017, 11:58 AM   #3
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
I'd say change it. Not sure how to do it on the turbo motor, but it should be about the same level of difficulty as an oil change.
soloknight6 is offline   Reply With Quote
Old 08-31-2017, 01:32 PM   #4
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Not hard at all, if you can change your oil the diff is no big deal... You'll just need a fluid transfer pump to put the fluid back in; can find them cheap on ebay.
I changed my rear diff fluid to red line after about 6000km and found some fairly nasty sludge on the magnetic drain plug... Also had a bit of that rear end grind people have been reporting; the fluid change took care of 80% of this... I'll change it again in the spring and hope the grinding is gone completely.
Car only has 6-8000km put on a year.
Can't claim to know the 'benifits' but I know with how I drive (and you by the sounds of it) that an early fluid swap to a high end fluid is cheap insurance.
Once you're a millionaire spread the wealth around to peeps who helped you out on the forum *wink wink
Lift car, remove top plug, remove bottom plug and drain fluid.
Clean off bottom plug and reinstall, pump fluid back into top hole until a little dribbles out, reinstall top plug.
I turned about a dozen figure eights in each direction to work it in a bit.
Burnout.
Beer.
Done.
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 09-03-2017, 02:25 PM   #5
Giri
Thank you guys. Plan to it next week
Old 09-18-2017, 02:21 PM   #6
Giri
I just changed my rear diff fluid. 1 inch long sludge buildup on bolt.
What's weird is that I only got 0.6 quarts out. I tried putting more in but it won't take more than 0.6q - and I let it drip for a long time. Did I do something wrong?
The car wasn't level when I did it, but the fill plug was higher than drain, so if anything it should have taken more rather than less?
Old 09-18-2017, 07:16 PM   #7
soloknight6
SoCal HT5! SD
The capacity for the auto diff in the V6 model is 0.53qts. Im certain the 4cyl and 6cyl autos share the same driveline, including the diff.
Old 09-19-2017, 08:15 AM   #8
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
If you look through the manual it tells you how much fluid you need and what fluid you need to buy. Just in case you forget in the future its a great reference to have. Also not sure how you changed it but harbor freight has a great siphon pump that works great for adding fluid back in.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
Old 09-19-2017, 10:02 AM   #9
Giri
Thank you so much! I really appreciate it.
I might have overfilled it a bit since I closed the fill hole while it was still flowing out + My car was jacked up in the back with the front already being half a foot lower than the mid point. What are the dangers of overfilling?
Old 09-19-2017, 11:47 AM   #10
soloknight6
SoCal HT5! SD
You did not really overfill. Old rule of thumb when filling diffs: "fill until oil slowly drips from the fill plug."
You may have added 0.6qts, but if some flowed out, it would have been closer to the 0.53 mark. You did no harm.
Old 06-15-2021, 11:06 PM   #11
NowaChevyGuy
NowaChevyGuy's Avatar
Drives: 2016 Camaro LT1 RS Black on Black
They actually are different. The V6 RS models come with a I believe 266 gear ratio and the manual 2.0 turbo comes with a 3.23 limited slip differential. I did this swap in my V6 so I definitely know. Can't recall how much fluid it took but the 3.23 with LSD is way awesome in the V6.
NowAChevyGuy
2016 RS - Trifecta Tuned, 3.23 diff swap, Borla S Type, JMS Throttle Controller, Lambo doors, Monster stereo, GM LED rear tail lights, BMR swaybars/End Links/Trailing Arms, tinted dark and murdered out.[/br]
Car kicks ass! $20k.. and I get 20mpg with my foot in it, everywhere I go!.... Say somethin about V6's now...
NowaChevyGuy is offline   Reply With Quote
Old 06-16-2021, 02:45 PM   #12
LtColumbo
LtColumbo's Avatar
Drives: 2017 1LT RS V6 A8, 2020 Fusion
My Mercury Grand Marquis came with the standard 2.73:1 rear-end gears. The Crown Vic Interceptor has 3.27:1 rear-end gears.
On a long trip from CA to CO, the stock gears were great for high-speed cruising on level ground, but sucked going up hills and a high altitudes.
After a bit of research, I had 3.55:1 gears put in. OMG! Burnouts in first, and a big chirp on the shift to second and the rear end would step out! It would pull strong on hills on the freeway and rarely shift out of 4th OD in doing so. I have a friend who has several CV Interceptors. He drove my car with the 3.55:1 gears and exclaimed, "WOW! This is much faster than mine!"
With the 2.73:1 gears, the engine was turning 1900 RPM @80 MPH. With the 3.55:1 gears, it was turning 2500 RPM @80 MPH. Not nearly as "relaxed." And I lost about 3 MPG on the highway.
LtColumbo is offline   Reply With Quote
Old 06-30-2021, 10:21 AM   #13
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Make sure you buy this hand operated pumper that threads on to the bottle
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
