Old 08-29-2017, 05:07 PM   #1
Drrewww_
Drives: 2017 Camaro SS
2017 Camaro 2ss can it use dual mode if it didn't have NPP?
I was thinking about purchasing the stainless works catback quad tips system for my 2017 Camaro 2SS. When I purchased the car I got the dual tip exhaust. I was curious to know whether the quad tips will work or if theirs a way to make my car have the dual mode capability if I need it? I know I will need to get a new rear bumper to get space for the quad tips.
Drrewww_ is offline   Reply With Quote
Old 08-29-2017, 05:11 PM   #2
SSport16
SSport16's Avatar
You would need to buy the rear fascia that is for the quad tips, has a piano black glossy finish to it and has wider openings for the tips.
Old 08-29-2017, 05:42 PM   #3
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
I think the issue is all of the electronics and controls that go along with it. Some discussion here:
http://www.camaro6.com/forums/showth...hlight=add+npp
Old 08-29-2017, 05:55 PM   #4
Drrewww_
That's exactly what I was searching for. I didn't know wether my car would support NPP since mine is isn't. I dont want to spend the money for it just to find out it's not fully compatible. Thanks for the help
Old 08-29-2017, 05:58 PM   #5
Hyper16
A Heartbeat Away.........
Hyper16's Avatar
Here's another thread I started on the subject.
http://www.camaro6.com/forums/showthread.php?t=450889
Old 08-29-2017, 06:07 PM   #6
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
As of now, I haven;t seen a dealer be able to update the MyLink setup and add the required wires/connections to make it work. You can for-sure add the pipes, but no way to update your car to make it function with the drive modes.
You can however go with an aftermarket option to open and close the outside pipes, and make it functional, but that would be a new system of controls and honestly it would end up being cheaper.
Sledgehammer70 is offline   Reply With Quote
Old 08-29-2017, 06:20 PM   #7
Drrewww_
Im able to install the full set up just won't be able to control it from the center console for the different modes I.e track, sport, tour,S&I. The only thing it'll be open at all times correct?
Old 08-29-2017, 06:49 PM   #8
Sledgehammer70
Lethal Camaro
Depends, you would need actuators on the car to open it or remove the pins the slide out the flaps.
But yes, you can install the pipes without any issues.
Old 08-29-2017, 07:30 PM   #9
glenB
Drives: Chevrolet Camaro SS
Wire it to a switch and relay, you can get creative or a simple open close
glenB is offline   Reply With Quote
dual mode exhaust, exhaust cat back, stainless works cat-back
