Old 08-27-2017, 05:44 AM   #1
Redhot6
Redhot6's Avatar
Drives: 2016 red hot 2ss
Tcm tuning?
can a tune help prevent/stop tc shudder
Redhot6 is offline   Reply With Quote
Old 08-27-2017, 06:50 AM   #2
Wiehl
Wiehl's Avatar
Drives: 2018 1LT LTG
If you have TC shudder, take it to the dealer and have the fluid changed. There is a bulletin with a procedure to stop that shudder.
Wiehl is offline   Reply With Quote
Old 08-27-2017, 07:05 AM   #3
AndyUK
Drives: 2017 Camaro SS
If that doesnt work you'll need it replaced so definitely not something you want to possibly void with a tune before taking it in.
AndyUK is offline   Reply With Quote
Old 08-27-2017, 02:26 PM   #4
Redhot6
Redhot6's Avatar
well see gm has a problem somewhere being my whole trans tc an all has already been replaced and the new one is doing it now so that returns me back to my original question of can you change anything with the tune to help or stop shudder
Old 08-29-2017, 08:42 AM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
Shudder is a mechanical problem not a tuning problem.
Are you sure it is not AFM vibration.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 02-26-2018, 08:57 PM   #6
Redhot6
Redhot6's Avatar
seems that I was correct that it is in fact a tune issue not a mechanical.
Old 02-27-2018, 09:09 AM   #7
JANNETTYRACING
No sir it is in fact a mechanical issue, that can be overridden with tuning.
The clutch material used in the converters along with the fluid chemical make up are the cause.
The dealer are flushing the transmissions, level 1, changing converters, level 2 and rebuilding the transmissions level 3 along with transmission reprogramming.
Old 02-27-2018, 12:11 PM   #8
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
I can confirm this has been my experience as well. Dealer told me the fluid was the cause. Triple flush and the shudder never returned.
Old 02-28-2018, 01:18 PM   #9
HorsePowerAddicts
HorsePowerAddicts's Avatar
Drives: LSx Powered
He's right You know
HorsePowerAddicts is offline   Reply With Quote
Old 02-28-2018, 03:50 PM   #10
jimmypop13
Drives: 2016 camaro ss
I got the triple flush, the shudder came back so I tried tuning it out by turning off DOD and zeroing the converter slip tables but the shudder was still there. Once you get the shudder back, it's already too late to try to tune it out. I didn't want a new torque converter that may shudder again so I figured either sell the car or go aftermarket. I went with a circle D converter and it's working great so far
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 07-26-2020, 03:48 PM   #11
neo85
Drives: camaro ss
When going with an aftermarket torque converter what else did you need to do, unlock and tune the TCM as well? Any issues since the converter change?
neo85 is offline   Reply With Quote
