Old 08-21-2017, 11:48 AM   #1
hudi60
Drives: 2017 2SS
2017 2ss exhaust
new 2017 2ss with dual mode exhaust sounds super great when i start it in the morning but gradually quiets down. Is there any way to keep the morning growl all the time.
hudi60 is offline   Reply With Quote
Old 08-21-2017, 01:01 PM   #2
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
I know when mine is warming up at 750 RPM there is a great bass sound that I love. The whole note is different but as it warms it idles down to 500-550. I love the sound of it with the higher idle.
JD555 is offline   Reply With Quote
Old 08-21-2017, 01:21 PM   #3
Bow Tie Affair
Drives: 6th. Gen ZL1
Originally Posted by hudi60 View Post
when I start in the morning it has a great growl sound then quiets down. Is there a way to keep that wonderful growl all the time.
Pull fuse# 51 in the engine compartment fuse box.
Bow Tie Affair is offline   Reply With Quote
Old 08-21-2017, 01:27 PM   #4
hudi60
Drives: 2017 2SS
will pulling the fuse cause any future issues
Old 08-21-2017, 01:31 PM   #5
mikem2104
mikem2104's Avatar
Drives: 18 2SS 1LE, 20 Canyon Denali
nope
Mike
Current Garage:
18' 2SS 1LE, Hyper Blue
23' GMC Canyon Denali
Previously:
20' GMC Canyon Denali
16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss)
14' Ford Edge Sport
06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada
mikem2104 is offline   Reply With Quote
Old 08-21-2017, 01:42 PM   #6
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Yes, Go into your settings on your infotainment screen and you can set how the NPP exhaust defaults.
Atomic Ed is offline   Reply With Quote
Old 08-21-2017, 01:55 PM   #7
Arugon
Arugon's Avatar
Drives: Summit White Camaro SS
Is that the AFM fuse, or the NPP Fuse?
Arugon is offline   Reply With Quote
Old 08-21-2017, 02:07 PM   #8
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
That's valve timing and fuel control both controlled by the ecu for start up cold only.
lt4camaro is offline   Reply With Quote
Old 08-21-2017, 02:15 PM   #9
Soleil
Soleil's Avatar
It is the NPP fuse. The AFM still works.
Soleil
Old 08-21-2017, 02:45 PM   #10
14Black1LESS
14Black1LESS's Avatar
Drives: 2014 2SS/RS/1LE
Put headers on it.
14Black1LESS is offline   Reply With Quote
Old 08-21-2017, 05:42 PM   #11
cnrad
cnrad's Avatar
Drives: a wagon
You can try doing the fuse pull, which keeps the exhaust valves open: http://www.camaro6.com/forums/showthread.php?t=441499 . That should help keep your exhaust from quieting down as much.
cnrad is offline   Reply With Quote
Old 08-21-2017, 05:44 PM   #12
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
Camaro6 probably a better place to ask...
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 08-21-2017, 05:45 PM   #13
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Yes op as others have stated your better off on Camaro6 for better info.
rontammy0 is offline   Reply With Quote
Old 08-21-2017, 06:26 PM   #14
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
This should help. Read your manual; If it has some sort of stealth mode make sure it's turned off. Certain driving modes will also change the volume output as well such as track or sport modes. If all else fails, headers.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
