Old 08-17-2017, 08:59 PM   #1
Calcanuck
Drives: 2017 Hyper Blue 2SS
Ratchet on stock SS seatbelts
I have seen people post about pulling the seat belt all the way out to get it to ratchet and then lock to keep you in the seat better. I can't seem to get the belt on my 2017 SS to do this. Is this only for the 1LE?
Calcanuck is offline   Reply With Quote
Old 08-18-2017, 07:55 AM   #2
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
I haven't tried that on my 1ss but what i do is pull my shoulder out from the belt.
place the belt under my left arm and make sure its tight on my body.
then pull the belt out as fast as you can. It should lock.
then slide your shoulder back in and it should be tight.
#53 F Street
2025 FS National Champion
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 08-18-2017, 09:45 AM   #3
Calcanuck
Good idea, I will try that.
Thanks
Old 08-18-2017, 10:04 AM   #4
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
I have also heard that if you back your seat up a bit, pull the belt snug and then adjust your seat to tighten it up, it will stay locked until you unbuckle it. Haven't confirmed it though.
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 08-18-2017, 10:16 AM   #5
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
I know my 16 SS doesn't have that feature. I had it on C6 Vette, so I thought newer Camaros would come with it, but sadly no. (it was one of the first thing I tried out when I got the car)
ZL1 has it. (I tried it in Becky's car)
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd
1100: 7/27/15 <SSWNNN>
3000: 9/04/15 <TPW:10/19/15>
3800: 10/19/15 <VIN: 117740>
6000: 12/16/15
jaymsu is offline   Reply With Quote
Old 08-18-2017, 10:57 AM   #6
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
My 1LE does have this feature, odd the normal SS wouldn't.
thescreensavers is offline   Reply With Quote
Old 08-19-2017, 08:57 PM   #7
Cap'n Pete
Cap'n Pete's Avatar
Drives: '02 Z28
LOVED this feature in my C6's as well.
ZL1 has it.
Good to know ........ thanks for confirming, guys.
It may be trivial to some people, but it's obviously a good thing to be held snug in your seat when you're ripping around the track! Seems silly that GM wouldn't just include it in ALL of the 'Vettes and Camaros!?!
Current car:
2017 Cruze Hatchback - oh yeah!
Previous cars:
2006 Z06 - LeMans Blue
2010 Corvette - LS3/MN6 - Black
2002 Camaro Z28 - LS1/T56 - Black
www.time-attack.ca
Cap'n Pete is offline   Reply With Quote
Old 08-23-2017, 10:14 PM   #8
Calcanuck
I wonder if you could fit the 1LE seat belt ratchet to an SS? I assume the mechanism is the only difference.
Old 08-23-2017, 10:44 PM   #9
Cap'n Pete
Cap'n Pete's Avatar
Drives: '02 Z28
I suspect it's likely an internal function of the belt retractor, therefore, most likely requires a replacement of the whole belt/retractor mechanism from a 1LE / ZL1, but I could be wrong?!?
Old 08-24-2017, 08:54 AM   #10
mbar
Drives: 2016 1SS
My 2016 1SS has it.
1. Move you seat backwards (and down) a few inches.
2. Start pulling the seat belt all the way. When you get almost to the end, pull it harder and you should hear a locking click. Release the belt quickly and it should lock on your body.
3. Move the seat forward and it should tighten the belt on your body.
If it does not work: just move your seat backwards a few inches / pull it quickly to lock the belt, then while the belt is locked move your seat forward.
Goodluck
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 08-24-2017, 08:22 PM   #11
Calcanuck
Originally Posted by mbar View Post
My 2016 1SS has it.
2. Start pulling the seat belt all the way. When you get almost to the end, pull it harder and you should hear a locking click. Release the belt quickly and it should be lock on your body.
Goodluck
The 1LE and Zl1 have a ratchet that kicks in with small clicks after you pull it out and let it retract. It will lock at any pinpoint along those clicks.
