Go Back   CAMARO6 > Members Area > Site Related Announcements / Suggestions / Feedback / Questions
Old 08-12-2017, 07:05 PM   #1
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
The search is always intermittently failing..
Regardless of using a forum search or advanced search, I enter in parameters and 50-75% of the time get a failure with an error 500 attached to it.
The "vbulletin sucks" excuse is lost on me as I visit many other vbulletin board sites without this issue...
Why has this been allowed to be such a pain point for so long?
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 08-13-2017, 09:25 AM   #2
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Getting errors certainly isn't part of the 'v-bull search is crap' thing.
Could you provide examples of the terms/parameters that you're using? It may help admin track down where the problem is coming from.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 08-13-2017, 01:10 PM   #3
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
I find if I use Google Search (second option down) from Search on the top menu, I get much better results than the built in site search.
KenKat is offline   Reply With Quote
Old 08-13-2017, 03:53 PM   #4
RideZX6R
RideZX6R's Avatar
Sure - Searched the 1le forum regarding it having the ZL1 fuel pump...
From forum search I'll enter the keywords, hit enter, wait a bit and I'm met with this page...
If I go to advanced search, I can select any parameters I want - I still get the same page.
Had the same experience yesterday (hence starting the thread) and intermittently for the last 6 months...
'12 E93 M3
'25 911 (ordered)
Formers...
Old 08-13-2017, 04:10 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Well, I just tried it myself and didn't have any issue when I searched the Camaro6 1LE subforum for 'fuel pump'. I was going to suggest that the problem may be with your browser (I use firefox, not chrome) ... but then I thought to try searching for 'zl1 fuel pump'. Thats when I got a blank screen with the same URL: http://www.camaro6.com/forums/search.php?do=process
I tried different combinations of 'ZL1', 'fuel', and 'pump' as well as a few other terms in place of 'zl1', like '1LE' and '1SS'. The search behaved normally whenever I did NOT include 'ZL1'; it was fine with everything else I've tried.
So it looks like somehow, including the term 'ZL1' breaks the site's search function. And I have now reached the limit of my usefulness, I simply don't know enough (or have access to) the inner workings of the site's code to do any more than diagnose where the problem is. Now its up to Tran and/or MarkLS2.
I guess for the time being, either use google to do a site search or figure out a way to ask about the ZL1 fuel pump without actually using 'ZL1' as a search term.
Old 08-13-2017, 04:13 PM   #6
I use Chrome 100% of the time and never get search errors.
Most of the time I'm searching titles only. Seems like it's a time out thing.
Old 08-13-2017, 07:03 PM   #7
h422694
h422694's Avatar
Drives: '16 Z06 7 Spd, 2024 High Country HD
500 errors are generally server side errors. There are several possible causes including memory shortages & corrupt files.
It's doubtful that any thing you can do on your PC will resolve the issue but you can try:
1 - Shutdown you browser
2 - Delete you cookies
3 - Restart you browser
h422694 is offline   Reply With Quote
Old 08-13-2017, 07:46 PM   #8
jrhagen
Drives: Camaro
I got stuck on "always intermittently". Which is it, always or intermittently?
jrhagen is offline   Reply With Quote
Old 08-21-2017, 03:19 PM   #9
ride98red
ride98red's Avatar
Drives: 2017 Summit White Chevy Camaro 2SS
for the love of all that is good PLEASE INVESTIGATE AND FIX THIS ISSUE!!!! Every time I try to search for posts or threads with "ZL1" or "1LE" I get that freakin 500 error!!! so annoying!
ride98red is offline   Reply With Quote
Old 08-21-2017, 03:26 PM   #10
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
I just go straight to google and search issue wanted + camaro5 at the end every time. Works like a charm!
SSEssence is offline   Reply With Quote
Old 08-22-2017, 10:54 AM   #11
RideZX6R
RideZX6R's Avatar
Would you prefer I said "Intermittently since I have started using this site" ?
Ie it's always been an intermittent issue for me, never resolved.
Looks like alphanumeric combos are causing a problem
'12 E93 M3
'25 911 (ordered)
Formers...
Old 09-06-2017, 09:27 PM   #12
MarkLS2
Administrator
MarkLS2's Avatar
Drives: 2009 Camaro
This should work better now.. maybe.. hopefully
Camaro....6!
MarkLS2 is offline   Reply With Quote
