Old 08-09-2017, 03:16 PM   #1
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
Does a "square" setup increase understeer??
This began to bother me back when all the offset discussions were taking place. Then when SeanBlur commented that he was not happy with 305's on the front with his new MRR FS-01 setup, it really made me wonder about the geometry of the car and how wheel sizes and offsets affect the track width ratio front to rear. EricSS commented in another thread about 10mm more track width in the front (because of spacers) was a good thing, it pushed me to share my thinking.
It was well documented on the 5th Gen that a square setup greatly reduced understeer. However, even on that car, the 1LE and ZL1 ran a higher offset rear wheel. I think right out of the box, the 6th Gen does not suffer from near as much understeer as the 5th Gen.
Using the 1LE stock setup as a baseline (+23 FR and +43RR), here is the math I came up with for a square setup. By going with +25 on the back, we increased the rear track by 10mm based on a 1LE's +43 offset. Stock 1LE is +20mm on the front so with a +25 on the front, we decreased front track by 10mm. So, now we have effectively decreased the front to rear ratio by 20mm (rear now being 20mm wider comparatively than a stock 1LE setup). Assuming you run a 5mm spacer on the front for camber purposes, you get 10 mm back. That leaves the back track width at 10mm greater than the 1LE. With or without out the spacers, theoretically, our square setup would actually increase understeer.....a wider rear track would cause push. Its just not as bad with spacers.
Is my math wrong? Is my thinking wrong? Or both?
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 08-09-2017, 05:17 PM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
How about accounting for the tire width.?
Old 08-09-2017, 09:05 PM   #3
LSmith353
LSmith353's Avatar
I don't know that tire width matters as much as where the outside edge of the tire is physically. If the rear track, which is outside to outside edge is wider than the front track, you get push. And I think it would push even if the rear tires are narrower than the fronts.
Old 08-09-2017, 09:33 PM   #4
BradfordCamaro
SABIO
My opinion is that a couple of mm is insignificant.
Old 08-09-2017, 10:12 PM   #5
LSmith353
LSmith353's Avatar
You may be right. Obviously, it looks like I'm the only one worried about it!
Old 08-12-2017, 01:02 AM   #6
grnflash
grnflash's Avatar
Drives: Hard
I have a square setup on 19x10's ET25 with 285/35R19. Your math involving rear track seems correct (or at least close), but the torque arm (during a turn, inside rear tire to outside front) is going to change by even less than the difference in tire track.
You're also dismissing... or at least minimizing... a big component of this issue. By going square (I'm going to use my tires above as a baseline), you're increasing rear contact patch by 10mm or +3.6%, however, you're increasing the front's by by 40mm or +16.3%. No matter what tire size you use, you are shifting traction forward vs. the stock setup when you go square. This is a significant increase in front traction.
My own experience has been very positive with this setup. The stock SS doesn't understeer badly, but it's definitely there. The square setup is an improvement, and it's remarkably neutral. What surprises me is actually that there isn't more oversteer. You *can* drive with the throttle with this setup, but you don't *have* to.
'16 2SS, 6MT, MRC, NPP, sways, square 285's—and an ear-to-ear grin!
grnflash is offline   Reply With Quote
Old 08-12-2017, 07:47 AM   #7
LSmith353
LSmith353's Avatar
You're also dismissing... or at least minimizing... a big component of this issue. By going square (I'm going to use my tires above as a baseline), you're increasing rear contact patch by 10mm or +3.6%, however, you're increasing the front's by by 40mm or +16.3%. No matter what tire size you use, you are shifting traction forwardvs. the stock setup*when you go square. This is a significant increase in front traction.
No doubt it's better than a stock SS setup, but I was referring to choosing a square setup vs. the 1LE setup. If I'm going to spend money on a track setup (I already did and am running same setup as you are), I would prefer to get the most performance from them as possible. However, as Bradford stated, at least at my skill level, 10mm is probably so negligible, it's unnoticeable. At the highest levels though, my guess is that it does matter.
Old 08-12-2017, 02:35 PM   #8
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
I think you guys are overthinking about the rear and front track. I've decided to run the car with 5mm spacer and then with 8mm spacer back to back and noticed 0 difference. It is very hard to tell the effect of a few mm, well at least for me it was the case
Speaking of understeer, in theory having a square setup vs a staggered setup should reduce the understeer but not directly but by inducing more oversteer. I don't feel like it's productive to address one issue by making the other worse.
Understeer was really bad with the Trofeo Rs (305/30/19 sq setup) that I previously had and surprisingly wasn't as bad with the 305/325 NT01s. This tells me that there are other factors that come in play such as having a softer sidewall.
I still have some understeer after -2.9 camber up front but it feels definitely better than before. I think the Multimatic suspension kit (if they ever offer that as they did for the Gen 5 Z28) will be the only real solution to address the understeer as the front is height adjustable and adjustable rear sway bar helps dial in the car
glamcem is offline   Reply With Quote
Old 08-12-2017, 03:44 PM   #9
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Why not get adjustable BMR swaybars to dial out the understeer?
WhiteNight is offline   Reply With Quote
Old 08-12-2017, 04:46 PM   #10
BradfordCamaro
SABIO
This is something I am honest about. Skill level.
As we know there are some very talented and skilled owners here that share their knowledge and set-ups.
We all want the 'hot set-up' and run what the big dogs do.
We all want (or think) to be 'That' guy. But I know I cannot drive like 'That' guy and problaby would not know what understeer feels like when it happens. Lol.
Basic thinking would lead you to believe that more width out back would add understeer....but so much more goes on when adding front Width, contact patch, tire compounds, etc.
And not all tires are the same width.....
Anyway... myself, I wil Drive and Adjust with what I have. Currently my simple 19 x 9.5 square meets my needs and I have not been able to find fault with it because for the way I drive I have not found the limits where I might conclude something needs changing.
Old 08-12-2017, 07:57 PM   #11
LSmith353
LSmith353's Avatar
Anyway... myself, I wil Drive and Adjust with what I have. Currently my simple 19 x 9.5 square meets my needs*
Now the truth is revealed.... I was looking for justification for a new set of wheels! Thought i had figured out a sure thing. Now I'm gonna have to think of another angle. Can't y'all help a brother out?!
Old 08-12-2017, 09:00 PM   #12
Redlinez
Shifts under load
Redlinez's Avatar
What kind of choices that aren't crazy money are there in 19x10 ET 25 wheels? Some that compare to Apex?
22 Suzuki GSX-S 1000GT blue
Old 08-12-2017, 09:09 PM   #13
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
a staggered wider rear setup would increase understeer. running a square would decrease it.
on the 5th gen, both JPSS (32mm) & GM on the 1LE and Z28 developed the huge rear bar, to help make the car more neutral to rotatable. that was the main advantage to going to such a larger bar in the rear.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 08-12-2017, 09:31 PM   #14
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Hence the adjustable BMR sway bar.
