Old 08-08-2017, 01:30 PM   #1
parish8
Drives: 17 SS a8
Forgestar f14 drag wheels?
Has anyone tried them? Do they even make what we need to fit on the car? I don't love the welds that so many people use and they are pretty pricey. The dark stars would work for me but I like the f14 in bronze burst a little better.
http://www.forgestar.com/dragracing/
So far the only thing I found out is the drag series wheels have a knurled bead.
Old 08-08-2017, 03:23 PM   #2
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
They do work we have done it before.
PK Auto Design is offline   Reply With Quote
Old 08-08-2017, 04:08 PM   #3
parish8
Drives: 17 SS a8
do you know exactly what to order. I am thinking the 17x10.5 but not sure on offset and I want to fit some 305/45/17 mt dr's on there.
for the front not a true skinny. maybe a 17x7 with a 28" tall radial.
all that and painted the bronze burst color. black lugs and if needed rings. can that be done?
Old 08-09-2017, 10:28 PM   #4
Chevy71
Drives: 2016 2SS
I'm wanting the sidewall benefits of the 17" wheel for my car as well. Have you test fit this sim rim on our car yet? I've heard it won't clear on a 2SS and you have to run 18", but I've also been told by some guys they are running 17" now. I don't want to do the conversion on my car, I want to be able to swap between my track rear wheels and my DD wheels
Chevy71 is offline   Reply With Quote
Old 08-10-2017, 03:47 PM   #5
PK Auto Design
They can do it for you
We normally do the following
18x5
17x10
Let me know I can make it happen for you.
Old 08-12-2017, 11:31 AM   #6
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Doesn't matter between 2ss or 1ss. Same brakes, unless you opted for 6pistons. I've test fit my 17x9.5 dark stars over my 6 piston. They clear, which leads me to believe their 17x4 would clear as well. They only JUST clear tho...no sticky weights on front with skinnies and 6 piston. But that's race star, not forgeline.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 08-12-2017, 12:17 PM   #7
parish8
Drives: 17 SS a8
18x5
17x10
I do not see the f14 listed anywhere in a 18x5. Do they really make that size?
If I am reading it right the 17x10 wheels won't have the bead knurling. Only the 17x10.5
Old 08-12-2017, 03:53 PM   #8
PK Auto Design
Logged into the inventory spreadsheet we use to check stock and verified the available options they have. As for the bead knurling I will need to check if the 10" doesnt but I believe it does.
Old 06-26-2018, 09:59 AM   #9
Gen5&Beyond
Gen5&Beyond's Avatar
Drives: 2016 2ss Camaro
Are you still selling the Forgestar wheels? I'm looking for the F14 17" drag pack. 17x9.5 rears and 17x4.5 fronts in Gunmetal.
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP
Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118
Gen5&Beyond is offline   Reply With Quote
Old 06-26-2018, 12:26 PM   #10
PK Auto Design
Yes sir I do
So normally we do a 18x5 and 17x10 from their dragpack
But they can produce a 17x4.5 front as well.
Old 06-27-2018, 06:23 PM   #11
ZNix
Drives: 1987 Buick Grand National
Will the 17x4.5 fit a standard SS brake setup? These are the wheels I would prefer, because I can get a 26" front runner on it.
ZNix is offline   Reply With Quote
Old 06-27-2018, 06:41 PM   #12
PK Auto Design
They can make them to work yes sir. They do not offer it as a option from their drag lineup so it is a special order we have them make from their blanks
