08-08-2017, 10:26 AM | #1 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
License Plate Bulb Housings Won't Hold Bulbs
Discovered one bulb out above my license plate, so I bought new LED bulbs to just go ahead and replace them both with.
Took one housing out and discovered no bulb, wire, nothing. I believe it fell out down in the bumper and I can't reach it. The housings look broke or maybe got hot and don't hold the bulbs anymore. Anyone else have this issue? Left side Right side no bulb or harness Sent from my iPhone using Tapatalk
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
08-08-2017, 11:30 AM | #2 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
I think I remember something about these lamps burning the plastic facia way back when the 5th gen was
new. Not positive though, but it may have been a warranty issue. I bet someone else here will remember.
08-08-2017, 02:05 PM | #3 |
I think there is a TSB on this exact thing.
08-08-2017, 02:09 PM | #4 |
Drives: Miss Con Ception Join Date: Aug 2016
It was never a recall so notices were never mailed out. It was a TSB, I believe.
Only those Camaros affected will be serviced for the issue. If you bring your car to the dealer with the issue they will install updated housings. This should apply even if your warranty has expired. BTW, if you remove your license plate there are two large openings where you will probably locate the missing socket.
2011 1SS/RS LS3 CGM
08-08-2017, 04:09 PM | #5 |
LSx FTW!!!
Cool.
I'll swing by a dealer and see if they can fix it. Thanks, guys!
08-08-2017, 06:15 PM | #6 | |
http://gm.oemdtc.com/4785/rear-fasci...evrolet-camaro |
08-08-2017, 08:19 PM | #7 |
Drives: 2010 SS Camaro Eforce SC Join Date: Mar 2017
WOW! Wish I had seen that before, I think I paid $57. For a harness and the 2 housings with lenses. Guess that doesn't sound so expensive, but free would have been really nice!
08-08-2017, 11:43 PM | #8 |
"BEASTM*DE"
If you paid for replacement parts you can show GM your invoice and get reimbursed...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
08-09-2017, 07:09 AM | #9 |
Factory Correct
Drives: 2011 2SS/RS Join Date: Dec 2011
Thanks of the info , my 2011 has never been to a dealership.
I think I'll get this done. |
08-09-2017, 10:41 AM | #10 | |
LSx FTW!!!
08-09-2017, 11:20 AM | #11 |
LSx FTW!!!
Found my bulb....
Melted in to some wire harness loom. :( Sent from my iPhone using Tapatalk
08-09-2017, 01:28 PM | #12 |
Drives: 2011 Synergy Green 2SS/RS Join Date: Mar 2008
Have only had my car since May, now I have something I need to check when I get home.
Hey, you want to lay the fate of the world on the kid's Camaro? That's cool.
I bought a car, turned out to be an alien robot. Who knew? |
08-10-2017, 06:56 AM | #13 |
LSx FTW!!!
Find anything?
08-10-2017, 04:56 PM | #14 |
Drives: 2011 L99 SS Join Date: Oct 2014
Mine melted on my 2011 in 2015, emailed GM, then got a call back, took about 30 minutes on the phone with India, I sent them my receipt, they sent me a check back.
