![]() Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Headliner flutter
I tried searching for this without success so sorry if it has been covered before.
Does anyone have a fix for the headliner fluttering above 40 mph with one or both windows down? It acts like a giant speaker and it is hard on your ears. Would like to cruise with the windows down but it kinda sucks right now. |
![]() Drives: 2017 1SS NPP A8 Join Date: Aug 2014
I happened to notice this the other day. I thought about putting some kind of glue under the edge of it but I'm afraid I'll make a mess. It does seem like this car is prone to making a flutter sound when traveling at speed. Kinda the same noise other cars make if you only have one window down at a time. I usually only roll both windows halfway down to prevent that noise.
#3 | |
![]() Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
![]() ![]() ![]() ![]() Drives: 66 Chevelle SS Join Date: Mar 2013
Funny this would come up. The window regulator in my '11 Silverado went south and the rear passenger window got stuck in the down position. The "Flutter" noise was unbearable. "Flutter" is a good description. Btw, my '66 Chevelle doesn't suffer from this anomoly with 1 window down.
66 Chevelle SS 396
91 octane Driver n/a 6.44@105.78 1/8th mile |
![]() Drives: 2016 Mosaic Black 2SS, NPP, A8. Join Date: Jun 2016
That's the reason I got my car with a sun roof. When it's open, you don't get the noise.
Sent from the mobile client - Forum Talker |
![]() Drives: 2016 2SS Red Hot Join Date: May 2016
Buffeting is an issue and usually corrected by only cracking the passenger window open or opening the sunroof (if you have one) to relieve the pressure being created. Funny, I was trying to find the other threads here regarding this and stumbled across this instead:
https://gm.oemdtc.com/6666/pic6189-w...evrolet-camaro
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
#8 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
Hmmmm...I've learned something new. I had always thought that it was just buffeting due to air pressure differential since I simultaneously experience pressure changes in my ears corresponding to the frequency of the fluttering; lowering a second window makes it go away. I also experience the same thing in my '14 Malibu.
#9 |
Seems that bulletin doesn't give any remedy. I was hoping there were maybe some Velcro or similar fasteners that could be installed at the center of the headliner to keep it from acting like the speaker at the beginning of Back to the Future.
#10 |
![]() Drives: . Join Date: Jul 2017
It's not just a Camaro issue. I've had this problem when I owned a Jeep Patriot, & my 2014 Silverado did it as well, no TSB's were ever created for it either. Would sound like a helicopter taking off. Its just the air rushing in the car through the headliner, not much can be done.
#11 |
![]() Drives: 2018 HBM SS 1LE Join Date: Jun 2017
I think you have cause and effect reversed.
#12 |
All I'm saying that it isn't just a Camaro issue.
#13 |
![]() Drives: '17 2SS 50th Join Date: Sep 2016
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
#14 |
I believe rootus was replying to OP.
The buffeting/pressure change is causing the headliner to 'flutter'.
