Old 08-05-2017, 01:14 AM   #1
2017Camaro2SS
Drives: 2SS
Keyfob will NOT UNLOCK my car! HELP!
Brand new camaro! Was heading to gym today but when I tried to unlock my door with the keyfob still in my pocket the door wouldn't open so I took out my keyfob and tried to unlock and NOTHING! So I logged into my Chevrolet app on my iPhone and tried to unlock it from there and again still no success! So I had to manually unlock with the key. When I am in my car I can't even lock or unlock the doors when I press on the buttons on both drivers and passengers side. Wtf !
2017Camaro2SS is offline   Reply With Quote
Old 08-05-2017, 01:44 AM   #2
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
You may need to check your settings...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 08-05-2017, 01:52 AM   #3
2017Camaro2SS
Drives: 2SS
Sorry what setting are you talking about ? Are you suggesting I have to do hardware reset ? None of this makes any sense right now ... everything worked perfectly fine for 3 month now. I could always unlock and lock my car with either with keyfob or with the keyless proximity.
Old 08-05-2017, 02:21 AM   #4
LuvMI
Lovin the growl...
LuvMI's Avatar
Drives: 2018 2SS
Mine did the same. Changed out fobs for a few days and it returned to normal. Dealer said something about freqs sometimes getting crossed with EMT's and 5-0 freqs.
Never had the door issue once inside the cabin tho.
LuvMI is offline   Reply With Quote
Old 08-05-2017, 02:39 AM   #5
2017Camaro2SS
Drives: 2SS
I don't think it's an issue with my fob since when I press unlock the front and red reverse lights come on. The fact that I can't unlock my car using my iPhone app means something else is wrong. Could it be a fuse ?
Old 08-05-2017, 09:48 AM   #6
PinHead
Drives: Duramax
Start looking up when you FOB doesn't work.
High Power Transmitters like Cellular and Radar Sites, Police/Commercial Radios/Repeaters, Microwave Transmitters etc, will likely block your low power(<100mw) Key FOB.
If that's not the problem you can try disconnecting the cars battery to reset the system and change the Key FOB Battery.
If that doesn't work the Dealer will need to Re-Flash the FOBS
Unfortunately we live in a high RF world, almost all appliances these days emit RF.
PinHead is offline   Reply With Quote
Old 08-05-2017, 09:51 AM   #7
PinHead
Drives: Duramax
Most likely not.
There's a encoded multicode (for lack of a longer post) that the Key FOB has to activate to accomplish a handshake with the car in order to unlock it
Old 08-05-2017, 09:54 AM   #8
RCF
Drives: '17 2SS, NGM, MRC, DPP; '19 F150
If pressing the lock/unlock buttons inside does nothing, to me it has to be something more than a key fob/interference issue. Don't have any clues as to what it could be tho... sorry!
RCF is offline   Reply With Quote
Old 08-05-2017, 11:55 AM   #9
gregmdusa
gregmdusa's Avatar
Drives: 2016 2SS NFG
I've seen a couple of videos about the hidden key in the fob...
Hope this helps...
gregmdusa is offline   Reply With Quote
Old 08-05-2017, 12:07 PM   #10
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Hope this helps...
That first video contained an interesting fact that I did not know: Even if the fob battery is dead, if you drop your fob into the rearmost of the 2 cup holders, there is circuitry in the car that will read the fob and allow the car to start.
So, dead fob does not mean dead car.
Emoto is offline   Reply With Quote
Old 08-05-2017, 02:46 PM   #11
Racerman27410
Racerman27410's Avatar
Drives: 2016 SS 2SS
I've had it happen to me..... i disconnected the battery ground in the trunk for 5 minutes and then reconnected.... everything worked fine afterwards.
Racerman27410 is offline   Reply With Quote
Old 08-06-2017, 07:01 PM   #12
mekirk2
mekirk2's Avatar
Drives: 2016 2SS Ragtop Garnet Red
Not sure about the coupes but the inside unlock buttons are disabled if the doors are locked on the convertibles. Supposed to keep someone from reaching in and unlocking the doors I guess - but if you pull the inside handles twice the door will open.
mekirk2 is offline   Reply With Quote
Old 08-06-2017, 07:08 PM   #13
Rustydaytons
Drives: Chevy
Heard Chevy don't unlock door for a weenie, are u a weenie?
Rustydaytons is offline   Reply With Quote
Old 08-06-2017, 07:18 PM   #14
WhyUMad1LE
Drives: 17 SS 1LE
Happened to me a couple times. Just spam the unlock button from outside the car.
