08-04-2017, 11:18 PM | #1 |
PhaSSt
Drives: 2011 Camaro SS Join Date: Jul 2017
Cam/Lifter Help
My father is a mechanic and will install everything for me BUT I have a question about the lifters.
I plan on getting new lifters but I do not know which lifters I can use or I need. I have a Lethal Racing Night Fury Cam. Any help, helps me out alot. I also am buying a trunnion upgrade, C5R timing chain, and 3 bolt camshaft kit. Thank you for all the help! |
08-04-2017, 11:45 PM | #2 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Any particular reason you are changing the lifters in it? AFM/DOD delete? Crazy cam specs?
Just curious what is wrong with the ones in it |
08-04-2017, 11:50 PM | #3 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
I put a new set of factory lifters in when I did my heads and cam.
08-05-2017, 02:13 AM | #4 |
PhaSSt
Many people have told me I should upgrade the lifters while I'm changing the cam out. I also seen many people say on forums to upgrade lifters if I'm not running stock cam. I have 61k miles on the engine, also I am putting kooks headers in while I'm at it.
2011 Camaro SS | Cat-Back Borla ATAK | Roto-Fab CAI | Night Fury Cam | Kooks 1 7/8 x 3" Headers
08-05-2017, 06:16 AM | #5 |
Drives: 2015 Camaro SS Join Date: Sep 2011
If you're going to do the lifters your going to have to pull the heads at that point you might as well get them ported.also don't forget to replace the lifter trays when I did my ported heads at 15K the lifter trays were a little loose holding the lifters compared to the new ones...I went back with the stock ls7/ls3 lifters
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
08-05-2017, 09:48 AM | #6 |
Drives: Camaro and Sierra Join Date: Jul 2012
As mentioned above, stock lifters will be fine to replace with if you decide to replace them. At 61k I would just for peace of mind.
08-05-2017, 04:58 PM | #7 | |
PhaSSt
08-06-2017, 05:54 AM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I think you are going to keep getting the same advice....if you replace...go stock.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-06-2017, 06:28 AM | #9 | |
way you will still need to measure for p-rod length.
08-06-2017, 08:53 AM | #10 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
And replacing the lifters is a must as they have established wear patterns in the stock stick if they have more than a few miles on them and have most likely some defects from the stock bump stick that may want to transfer into problems for the new one let alone the wear they take. I use BTW driven racing oil BR30 to break in even a cam not just a whole engine..... And dad should know you have 1.7 ratio rockers so setting the preload into the golden .040-.060 area for stock ls3/7 for low noise is about 3/4 turn being that the .047 thread pitch of the bolts threads for the rockers move the rocker .047 x 1.7 for actual movement with whole turn.......
08-07-2017, 10:09 AM | #11 | |
I am looking at doing a cam swap, and it seems like a lot of people don't even pull the heads for the change. Many I have read about just change out the pushrods and springs, but leave the lifters. I didn't plan on changing mine. But I also only have like 20k on them |
08-07-2017, 05:35 PM | #12 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
Johnson 2110 Lifters
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
08-09-2017, 09:46 AM | #13 |
Drives: 2019 Camaro 1SS A10 Join Date: Nov 2015
Installed a cam around 70K and chose to replace my entire valve train including lifters and lifter retainers. Installed new GM pieces and all has been well.
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6 2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD** 2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD* 2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD* Last edited by gmcvt; 08-09-2017 at 10:01 AM. |
08-09-2017, 05:31 PM | #14 |
Drives: 2012 ls3 Join Date: Feb 2014
First cam lasted almost 20k before original lifter collapse. Second time around another shop swore by LS7 lifters and now 469 rwhp on mustang dyno and almost 60k miles on new set up not a problem or worry yet
Tags |
camaro ss cam, camshaft, lifters |
