Old 08-04-2017, 11:40 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
2 stock ZL1 1/4 mile passes tonight
I took my car to Richmond Dragway tonight for 2 passes which were not too bad considering the heat and stock tires. DA was +2200 ft. I lowered the air pressure to 21 psi in the rears and increased front pressure to 45psi. I left the car in "D" with a seven second hold of the traction control button to turn off traction control and stabilitrak. I left the suspension setting in Tour. No burnout...just a clean off before rolling to the line. Here are both runs:
60' 1.87 1.93
330' 5.0536 5.1086
1/8 7.6078 7.6618
mph 97.38 97.42
1000' no clock
1/4 11.6164 11.6584
mph 123.63 124.79
Not bad considering the DA and tenative launch. I don't think I've had an easier time running a mid 11. It was like a drive to the grocery store.
Old 08-04-2017, 11:48 PM   #2
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Did you put in it a PTM mode?
ninetres is offline   Reply With Quote
Old 08-04-2017, 11:59 PM   #3
Stephen12ZL1
Drives: '21 ZLE A10
no PTM modes...just nannies off. Hold the traction control button until both lights illuminate.
Old 08-05-2017, 12:10 AM   #4
396ssrat
Drives: 66 Chevelle SS
This is where this car should be. It can improve a bit. Good job....
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
Old 08-05-2017, 12:24 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Nice!
Old 08-05-2017, 12:31 AM   #6
The A10 won't go into performance shifting in tour mode. I would at least drop to tour or track. Good solid runs though.
Old 08-05-2017, 01:49 AM   #7
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Nice runs...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 08-05-2017, 08:08 AM   #8
Stephen12ZL1
Drives: '21 ZLE A10
Had no idea about that. I will try again in Sport or Track.
Old 08-05-2017, 09:06 AM   #9
curtislowerussell
curtislowerussell's Avatar
Drives: 2016 Black 2 SS/ 2017 ZL1 Yellow
I have seen people say they had better times in Tour. I wonder why?? Next you should take it to Va motor sports park it's a great track too.
curtislowerussell is offline   Reply With Quote
Old 08-05-2017, 09:42 AM   #10
During normal driving you can blip the throttle and it will jump to ~4k rpms and hold and performance shift message will display. Or when you get aggressive with the throttle it shifts harder. It won't do this in tour. Not sure if it really makes a difference at WOT but doesn't hurt to be sure.
Also, I was able to hit 1.80 on stock, full air pressure tires using race mode and just stalling it to 1500 at the line.
Probably because all the nannies are on and it's giving sort of a launch control. Quite sure if they really got into the settings tour would not be the way to go on a prepped track. The A10 just hasn't been out long enough for folks to really work through all the settings.
Old 08-05-2017, 10:09 AM   #11
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Nice runs, I race there a lot and Virginia Motorsportspark, I will be probably start going back in a few weeks when it cools down outside.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 08-05-2017, 10:12 AM   #12
NJSRT
NJSRT's Avatar
Drives: 2016 Challenger Hellcat
Nice runs. Your trap speeds look very good. I personally look at that to determine how fast the car is.
NJSRT is offline   Reply With Quote
Old 08-05-2017, 10:19 AM   #13
Sftshldr
Beast Rider
Sftshldr's Avatar
Drives: 2017 ZL1 BLK A10
Wishlist item.
Performance supplement.
How to get the best results, use, functionality, by category, using the various electronic settings and options of your new Camaro. Compiled by Chevrolet Performance engineers.
If only ..........
"Just looking fast is sometimes all it takes!!!"
Sftshldr is offline   Reply With Quote
Old 08-05-2017, 11:00 AM   #14
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Do the tires need to be warmed up? I know it is debatable heating up street tires, but these aren't normal street tires.
Sent from my SM-G955U using Tapatalk
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
