Old 08-03-2017, 01:02 PM   #1
Paully104
Novice Driver
Paully104's Avatar
Drives: 2016 2SS Silver
DSC V2 Controller Installed & Review
Hello everyone,
I recently purchased the DSC v2 controller and had the pleasure of testing it for a couple hours now. My general use case is as a daily driver and for entertainment, I have not taken my car to the track. With that in mind the installation is suppose to be fairly simple. I requested that future boards going out are 1/2inch shorter for the 2SS Camaro as the fitment is pretty tight. Additionally since its a pin connector if you do not connect it perfect you can get a warning that your suspension needs maintenance. I had to get the part replaced as a pin was slightly out of position. Once I installed the replacement I haven't had an issue yet.
The controller makes a noticeable difference and its easy to test by swapping the stock controller and the DSC v2. Touring is not only more gentle but you feel more confident in turns and I do not get any floating feeling. In track mode I drove out to Mexico and was impressed with how I was able to corner. At the very least this component inspires confidence. I had a test with my wife to guess what part was in and she was able to point out the difference. Her exact words were the stock controller feels "clunky" compared to the DSC V2.
Technical mishaps I would like to note to prevent people from being as dumb as me.
1) You can use WD40 to make the connector slide on easier, be careful not to get WD40 on the pins. If the pins are not fully connected or if you get WD40 on the pins and start your car your going to throw like 15 codes. Do not panic just unplug and make sure the pins are clean and put it back together. Then disconnect the negative terminal and walk away for 15 minutes and come back. Your car will start and should have no codes.
2) Check which way the pins are, one side is a 1 straight line and the other side is two rows. You wont bend the pins but you could sink the pins which can cause connectivity issues. I think this is how I messed up my first one.
I'd like to note that the shop was extremely helpful and took my calls. When I needed a replacement they sent it as a overnight. They stated if any firmware updates happened in the future they can send a board out and I can send mine to them. While I was nervous about my original board showing issues I'm glad I learned how helpful the shop was.
Edit: Had connection issues with the second board. Ending up returning and going to see if other folks are having issues. I spoke with the shop several times attempting to resolve the issue but for whatever reason I kept getting suspension warnings on the dash.
Modifications: BMR suspension & front brace, DSC v2 controller, ported throttle body, Rotofab intake, Rimblades rim protection (red)
Paully104 is offline   Reply With Quote
Old 08-03-2017, 04:00 PM   #2
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Thanks for your initial review! This was what I was expecting to hear given what the corvette folks have been posting about the controller.
Did you zero out the ride height yet? I also noted that they said something to you about firmware updates via a new board. I thought that firmware (we're not talking software updates) updates were still through a laptop?
Keep us updated as you use it, and in particular, if you play around with the tuning.
Atomic Ed is offline   Reply With Quote
Old 08-03-2017, 04:12 PM   #3
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Instead of using WD-40 and having to worry if it got on the pins and even on plastics, I'd use CRC 2-26 which is like 3$ at home Depot.
thescreensavers is offline   Reply With Quote
Old 08-03-2017, 04:49 PM   #4
Paully104
Novice Driver
Paully104's Avatar
I'll have to look at CRC 2-26 , the WD-40 trick was told to me by them. Hopefully this saves someone a headache.
Old 08-03-2017, 04:50 PM   #5
Paully104
Novice Driver
Paully104's Avatar
I read about zeroing out the ride height but that was not in the instructions I received. The instructions for the Camaro just stated to plug it in and drive.
Old 08-03-2017, 04:57 PM   #6
Atomic Ed
Give them a call and let them walk you through it. Supposedly an easy thing to do and worth the effort.
Or, I just remembered there is a youtube on it somewhere.
Old 08-03-2017, 09:16 PM   #7
bubbajan21
Drives: 2016 2SS
This one?
BMR stated that our ride height sensors do not measure ride height but rather the rate of change. I guess the if the DSC controller can output a value for ride height then they are wrong.
bubbajan21 is offline   Reply With Quote
Old 08-03-2017, 11:45 PM   #8
Atomic Ed
Originally Posted by bubbajan21 View Post
This one?
I believe this is a matter of semantics. This looks like nothing more than zeroing out the static, at rest condition for the vehicle with the driver in it. I believe this step simply matches up the sensors with the controller.
I don't see anything in this video trying to output actual ride height.
Old 08-08-2017, 10:45 AM   #9
Paully104
Novice Driver
Paully104's Avatar
I gave them a call and this is something that you do. They said that its pre programmed for stock height but if you lower your car you should do it right away.
Old 08-08-2017, 11:06 AM   #10
Atomic Ed
Paully,
Now that you have lived with it for a while, any additional observations?
Old 08-08-2017, 04:58 PM   #11
JaxChris
Does the v2 offered for the Gen6 Camaro include WiFi connectivity so you can leave it in the car for adjustments?
Old 08-09-2017, 03:40 PM   #12
Paully104
Novice Driver
Paully104's Avatar
No wifi was advertised the board has a USB slot that you can connect a laptop to.
Old 08-09-2017, 03:41 PM   #13
Paully104
Novice Driver
Paully104's Avatar
Paully,
I've stopped using my brakes to go around corners because my car turns so well haha. Honestly it feels fantastic compared to stock and I think this is a good part to get.
Old 08-10-2017, 10:06 AM   #14
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Oops just saw this thread. Thank you for the impressions!
