Old 08-02-2017, 08:14 PM   #1
DeliveryMan
Trans Oil Line Recall....ALIGNMENT NEEDED?
I got my car back and the steering does not seem quite as tight as it was. The I usually leave it the Steering setting in Sport mode.
It is tight at higher speeds but seems a little loose at very low speeds.
I noticed in the Bulletin for the Trans Oil Recall that the Rack and pinion bolts need to be removed.
I have in a different thread that an ALIGNMENT was done to an owner's car after the recall job was done (the owner posted the pic of the invoice and the Alignment was on the same section as the trans oil line recall)
Does anyone have any further information or insight on this?
Thanks
DeliveryMan is offline   Reply With Quote
Old 08-02-2017, 09:07 PM   #2
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
Tight and alignment do not equate, two different things.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
Old 08-31-2017, 07:03 PM   #3
godeepdown
Jeremy Frye
godeepdown's Avatar
Drives: 2016 Hyper blue 1SS
My steering was off a little after the recall too. Not sure why they would have had to mess with that.
godeepdown is offline   Reply With Quote
Old 09-01-2017, 04:42 AM   #4
Reaper333
Drives: 2016 Camaro 2SS Black..
Rack and pinion has to be loosened or removed to do the recall from what I have read. After the recall my alignment was way off along with the steering wheel being crooked. I ended up having to have several alignments and eventually I had to have my rack and pinion replaced at 10k miles. I have no idea what they did but they messed mine up pretty good.
Reaper333 is offline   Reply With Quote
rack and pinion, recall, trans oil line
