Old 07-29-2017, 02:42 PM   #1
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
Waiting for update media screen?? My link issue or normal Update?
Any one seen this? It screen went blank when I started it this morning now it's stuck on this. Won't even go away when it's off.
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 07-29-2017, 03:10 PM   #2
chris227
chris227's Avatar
Had this happen once. I disconnected all the plugs going to amp. Then i started the car and ran for a min or 2, then turned off the car and waited 5 min and plugged all the plugs back in and it was gone. It's the hmi update screen.
Old 07-29-2017, 03:11 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Disconnect the neg batt cable for a couple hours and reconnect.
Old 07-29-2017, 05:48 PM   #4
talon90
talon90's Avatar
Drives: 2017 Red Hot 2LT RS
As noted, that isn't a normal screen. That is a system update screen and generally, shouldn't be user accessible. If you have a USB drive plugged in, there could be a stray file on it triggering the update routine, or in the unlikely event that you may have plugged something in to the USB port under the dash.
Unplug all devices and cables, power down the car (and system) and disconnect the negative battery terminal.
If you see this more than once, let your dealer take a look at it.
If you are using a USB media drive, you might consider moving your files off it, reformatting and then copying your media back, paying attention to the files that come over.
talon90 is offline   Reply With Quote
Old 07-30-2017, 06:03 PM   #5
chrest
chrest's Avatar
Nothing in the USB drive. Just came out of no where. Disconnected the negative terminal and it came back all normal.
I got a few things to discus with the dealer now when I take it in for first oil change but man, I feel like I need to disconnect the negative just a little more than I should....
Hurst shifter
603hp/547tq
Old 07-30-2017, 09:08 PM   #6
camaro104
camaro104's Avatar
Drives: 2017 Nightfall 50th Annivers Camaro
Send a message via AIM to camaro104
Leave it it will pass, it's doing an up date, it happen to mine. It will take awhile.
camaro104 is offline   Reply With Quote
Old 07-31-2017, 08:32 AM   #7
TJay74
GM is now pushing some updates out thru the OnStar data system in the cars. I've seen this screen in my 2016 Sierra, supposedly it will update and go away on its own.
Old 07-31-2017, 11:19 AM   #8
chrest
chrest's Avatar
all is well now. Upon searching, i found a thread on a Colorado forum about this and they said its dealer time no matter what. Guess those boys aren't hip to the negative terminal pull lol
Hurst shifter
603hp/547tq
Old 08-20-2017, 04:47 PM   #9
Nickjensz
Drives: 2017 Camaro 2 SS
Just happened to my 2017 2SS today. Started the car up after lunch and the screen was black at first. Shut the car off / back on and then the waiting for update media screen came back on.
Chrest, Have you brought yours into the dealer yet? Just curious what they did if anything.
Cheers!
Nickjensz is offline   Reply With Quote
Old 08-21-2017, 08:48 AM   #10
chrest
chrest's Avatar
i did not. I pulled the negative cable for a while and when i hooked it back up all was well.
Ive had a couple different weird electrical gremlins since ive owned this thing and a negative battery cable pull always seems to fix my issues.
I have lots to discus when i take this in for its oil change. I try to avoid the dealer as much as possible but i will inquire about some of these issues ive had
Hurst shifter
603hp/547tq
Old 08-21-2017, 09:45 AM   #11
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Now imagine you're just driving along with Android Auto and Google Maps / Waze running you to your destination of which you've never been to before and POOF that screen appears!
Need4Camaro is offline   Reply With Quote
Old 08-21-2017, 11:14 AM   #12
Nickjensz
Went out this morning, and mine was working fine... I didn't even pull the battery cable. I still dropped it off at the dealer this morning, and told them to take a look at it.
Thanks again for the quick reply!
Old 08-21-2017, 11:18 AM   #13
Nickjensz
that would suck! I hope whatever the ghost in the machine is that is making this happen gets sorted out. My dealer was less than friendly this morning when I dropped it off, and didn't even seem interested in having me explain what happened. So, I guess we'll see what they figure out, if they even look at it.
Old 08-21-2017, 03:32 PM   #14
Nickjensz
Well, just a quick update. I got the car back from the dealer and they said that an update for the HMI was needed. They applied the update and said I should be fine going forward. I guess we shall see.
Happy motoring Gang!
