Old 07-27-2017, 12:29 PM   #1
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
Vengeance Racing - First 1000+rwhp ZL1 LT4 PROCHARGED (Air to Water IC)
Enjoy!
aka Reckless is offline   Reply With Quote
Old 07-29-2017, 07:39 PM   #2
80sMetalDude
80sMetalDude's Avatar
Drives: .
They do the best videos. Badass. Music is sick love it...
80sMetalDude is offline   Reply With Quote
Old 07-30-2017, 12:35 PM   #3
17 White ZL1
17 White ZL1's Avatar
Drives: 2017 White ZL1 A10
One of the best engine bays I've seen in a ZL1 or Camaro. That LME intake is amazing but Big $$$$
2018 Trackhawk
2017 ZL1 A10
2017 CTSV
2016 GT350
2015 Hellcat Challeger
17 White ZL1 is offline   Reply With Quote
Old 08-01-2017, 10:48 AM   #4
aka Reckless
We took our "VR1100" 6th Gen ZL1 and managed several 9.5x@152mph passes on factory 20" wheels with Mickey Thompson Drag Radials.... There is another two to three tenths left in this combo, but we ran out of time and were taking "baby steps" with this new A10 transmission....
Shakedown was at the "House of Hook" in South Carolina yesterday. Had some issues on and off with the crank sensor and tach signal. Last pass we had to lift at about 1100ft and coasted to 132mph and a 9.40's pass. Still some tuning left, but it will easily run 9.20's on 20-inch DR's.
This also should be the quickest/fastest 6th Gen ZL1 in the country... More to come!!!!
Old 08-02-2017, 10:47 AM   #5
aka Reckless
A few photos of the air-to-water setup that tucks nicely into the front bumper
Old 08-02-2017, 10:59 AM   #6
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
ProCharger for the win!
Perdieu is offline   Reply With Quote
Old 08-02-2017, 11:30 AM   #7
aka Reckless
I knew I had seen photos somewhere else Tim
Old 08-02-2017, 03:39 PM   #8
Perdieu
Perdieu's Avatar
LOL yep..
Old 08-02-2017, 05:52 PM   #9
PRAY
PRAY's Avatar
Drives: 2016 2SS
SSSSIIIIIIIIICCCCCCKKKKKK!!!!!!!!
Old 08-06-2017, 11:27 AM   #10
IneedAZ
IneedAZ's Avatar
How much more power does it take to drop to 8.9 when already going 9.5? The car is already a couple hundred more hp than the demon but not that much lower in et. Lot more mph though. What do u think is holding it back from a 8.9x run?
Old 08-06-2017, 12:33 PM   #11
PRAY
PRAY's Avatar
Drives: 2016 2SS
If the MPH is there for an 8.9 run then no more power is needed to get the car there. The car set up needs to be there to get it done.
The Demon was run on race gas, on a drag pack, stripped down with the suspension tweaked for the 1/4 mile. Power is only a tiny bit of the equation when getting a car down the strip. Things get much more difficult as you get into the sub 10 second range. Put the Vengeance car on a proper drag pack with a solid trans tune and race gas with all the seats and extra crap yanked and there is probably another .5 in it if not more. DA also has a lot to do with ET and mph. No where that I know of right now is going to see DA under 2K if not 2,500. The Demon I believe also has a trick set up to launch the Auto at 4K or something like that. All you are going to get out of the A10 converter is possibly 2K. Slap a Circle D 4C in the ZL1 and things are going to get silly. Getting this car in the 8's shouldn't be hard at all when it is dialed in with good weather.
Old 08-06-2017, 01:29 PM   #12
aka Reckless
Correct. This is a stock suspension and the only thing changed was addition of drag radials, but still a 20-inch wheel, so short sidewalls. I'll have to see what the 60-foot times were like.
