![]() Drives: 2017 Camaro SS M6 Join Date: Apr 2017
Question for those who swapped out their Goodyears?
I recently put on some Nitto NT555 G2's on my rear that are 275/30/20. Same as the OEM tires except a smaller profile. I kept the tire pressure about the same as the OEM tires. Basically, when I step on it on the car, the tires don't spin as much as the Goodyears, but the car in generally gets a little swirly. Anyone else have similar experiences? Might it be the smaller tire profile? What PSI are you guys running on your tires?
BTW, these tires are temporary as I'm waiting for some wheels I ordered to come in and then those NT555 G2's will be swapped to the front and getting some NT555R's in the back (305/35/20). So that might help stabilize the car more? |
![]() Drives: Hyperblue 2016 1SS Join Date: Jul 2016
Same thing here I went with the stock size Sumitomo HTR ZIII's and the car grips a bit better but seems to sway away from the line.
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Be careful mixing tire types front and rear, and changing tire profiles.
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
I went with stock size Continental DWS 06. They do not spin as much as the stock run-flats. I find that to be a good thing.
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
Yeah, looks like a lot of diff brand tires don't spin as much as the run-flats. Did you notice your cars behavior change however? Especially under WOT?
#7 |
Not that much. However, I changed tires shortly after break-in so I never pushed the run-flats that hard.
#8 | |
![]() Drives: Fifty Join Date: Nov 2016
I had a g8 gt that I put Sumitomos on and now I've done the same with my Fifty. however I'm not getting the issues that you are. Mine seem just as tight as the oem tire that I had on. These are good tires and they are not to expensive. Especially if you stay stock size. Got all 4 for 648.00.
#9 |
Moderator.ca
Thread Moved
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#10 |
Retired from Car mfrs....
33-35 on my nittos
#11 |
#12 |
Went to Nitto invos from the goodyears, ride quieter, handling fine, I am a DD guy, not a track guy. The Goodyears being run flats, ride hard, and therefore they can spin the tires better. I don't care about any Of that. Just passed 10k miles, tread life still looks almost new. This is my third set of invo's on cars, they are a great value and work perfect for me.
#13 |
![]() Drives: 2016 2SS Join Date: Nov 2016
Replaced run-flats with Continental ExtremeContact Summer tires. Looking to sell my stock run-flats with < a thousand miles on them if there is any interest out there.
#14 |
If you haven't done so already, you should post in the Wheels/Tires section of Member Classifieds
