Old 07-26-2017, 02:53 AM   #1
heckler45
Drives: 2018 1ss 1le Hyper Blue Metallic
On the road flat fix
What do you guys do when you're on the road and have a flat? I plan on getting a better compressor than what comes with the car. I was wondering what jack to use. Harbor Freight 1 1/2 ton racing jack? Its light weight. Or just get a scissor jack and a Dr. Roc adapter to use with a rachet or a 12volt impact? I don't want to use the slime. I am gonna plug if I ever have too.
heckler45 is offline   Reply With Quote
Old 07-26-2017, 07:21 AM   #2
TJay74
I bought a plug kit, the OEM compressor will air the tire up just fine. I plan on just rolling the tire over to where I can remove the offending item and put the plug in it and air the tire back up.
Old 07-26-2017, 11:07 AM   #3
ddanj
Drives: 2018 1LS 1LE
But what if it's sidewall damage from a pothole? I've had that happened to me about two years ago :( luckily I was about two miles from home so I just limped the car super slow back to the house.
I'm just about to order a Camaro - they all come with an oem compressor? Is it in the trunk?
ddanj is offline   Reply With Quote
Old 07-26-2017, 12:03 PM   #4
TJay74
No, if it is a regular SS they come with run flat tires. Only the 1LE models get the compressor and slime.
I think the Camaro SS gets roadside assistance as well for a non-repairable flat. Also most of the run flat tires and I know Continental and Michelin both tow up to 150 miles due to a flat.
Old 07-26-2017, 01:17 PM   #5
ddanj
Interesting. I'm ordering a V6 1LE. I wonder if it will come with the compressor and the slime.
I had RF tires on my current car, and switched out to regular tires once the old ones wore out. The car's ride quality improved for sure with the regular tires. I was planning to do something similar with the 1LE.
Old 07-26-2017, 02:33 PM   #6
HOUTX1LE
HOUTX1LE's Avatar
Drives: Camaro 1LE
Good info to know.
2017 Camaro SS 1LE
HOUTX1LE is offline   Reply With Quote
Old 07-26-2017, 11:41 PM   #7
heckler45
TJay74. How is there enough room to remove object and install plug? Surely you are jacking car up? What jack do you use?
Old 07-27-2017, 07:56 AM   #8
TJay74
I will just roll the car over until the object is in a place where I can remove it, then install the plug. I've done it that way before on a Vette and it worked just fine.
I have no intentions of carrying a jack in the trunk.
Old 07-27-2017, 12:31 PM   #9
TunaMelt
Drives: 2017 Camaro SS 1LE
That's what I do on my Volt and plan to do with this car. A plug kit and rubber cement is only a few bucks and will solve most of your problems or at least let you limp home. I just don't feel like spending the cash and extra weight on a spare and jack.
TunaMelt is offline   Reply With Quote
Old 07-27-2017, 02:40 PM   #10
Sleeks
Drives: None
This is also what I am doing. Plug kit, a piece of chalk, gloves, pliers are all in the trunk just in case.
-Brian
Hyper Blue 1SS / 1LE
Sleeks is offline   Reply With Quote
Old 07-27-2017, 03:13 PM   #11
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
As soon as I ditched the run flats, I started to carry a plug kit. I have almost all the pieces needed to build a small (20oz.) CO2 tank to mount in the trunk to refill once I plug the tire. If it's a bad blowout, I can always call roadside assistance under my warrantee or my insurance.
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 07-27-2017, 05:20 PM   #12
ddanj
Why not use a can of fix-a-flat? has anyone had experience with it?
2018 Garnet Red 1LS 1LE V6 w/Tech
1100 - 07/26/2017 | 4300 - 09/15/2017 at rail yard
3000 - 08/16/2017 | 4200 - 09/18/2017 shipped!
3100 - 08/19/2017 TPW 09/11/2017 | 4800 - 09/20/2017 train journey done
3400 - 08/25/2017 | 5000 - 09/22/2017 at the dealer, and picked up!
4300 - 09/12/2017 Built! VIN available
4B00 - 09/14/2017 move to rail yard
Old 07-28-2017, 07:26 AM   #13
TJay74
That stuff wreaks havoc with the TPMS sensors. It also leaves a nasty film on the inside of the wheel and tire.
Old 07-28-2017, 08:42 AM   #14
TunaMelt
The only two flats I've experienced were both on the shoulder where the inflator sealant came out and wouldn't seal. I would imagine fix a flat doing the same. Spend the two bucks and throw a cheapo plug kit in your car for another option. It's too light and cheap not to have one in every ride you own.
