Old 07-25-2017, 09:47 AM   #1
Purekoryo
Are you guys pulling timing with basic bolt on's and NO TUNE?
16' SS A8
Mods:
Rotofab CAI
PRAY Ported IM / TB
MBRP Catback
STOCK TUNE
Any of you guys with similar mods with STOCK tune pulling timing? Don't really want to spend $ on a aeroforce gauge just to log timing at this point until I find any one person that has seen definite timing retard with these type of mods.
Thanks in advance!
Purekoryo is offline   Reply With Quote
Old 07-25-2017, 10:03 AM   #2
F1FTY
Drives: 2018 ZL1
My mod list is quite similar (GM CAI, Katech ported TB, PRAY ported IM). I need to do some data logging and will find out shortly. No noticeable downside in drivability so far. The car does have the GM CAI MAF tune on it, but your Rotofab shouldn't require that.
F1FTY is offline   Reply With Quote
Old 07-25-2017, 10:45 AM   #3
Purekoryo
Yes, sure would appreciate checking back to show us your logs. Did you notice any improvements on your butt dyno?
Any others?
Old 07-25-2017, 10:52 AM   #4
F1FTY
Drives: 2018 ZL1
Any others?
Will gather them, need to do that anyway to start tuning.
Improvement is very noticeable with this combo. Car feels like it's gained more displacement due to increase in torque and power through the entire power band. I credit a lot of it to PRAY's IM since I did the mods in stages.
Old 07-25-2017, 11:50 AM   #5
Purekoryo
Did you do any 0-60 and 1/4 mile pulls?
Old 07-25-2017, 02:48 PM   #6
Jessyb13
Jessyb13's Avatar
Drives: 2017 Camaro 1SS
i have similar and the definitely doesn't run any worse with no tune..
2017 Hyper Blue 1SS (M6) / (20x10.5)(20x9.5) Feradda FR2 Wheels / Mishimoto CAI / Kooks 1 7/8” Catless Longtube Headers / Custom 3” Mid-Pipe w/ Flowmaster Super 10 Mufflers / Mishimoto Catch Can
Jessyb13 is offline   Reply With Quote
Old 08-06-2017, 11:06 PM   #7
SUMMITWHITE1SS
Drives: 2017 A8 1SS
I have the Gm cold air.(no tune) since i am in california. I also have the katech TB and will be installing a pray ported IM within thw next couple days. I was worried it would run too lean with this combo or maybe throwsome codes. @fifty any drivability problems on the stock tune? since i would have the same setup as you?
SUMMITWHITE1SS is offline   Reply With Quote
Old 08-07-2017, 12:39 AM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
i have pray ported TB/IM and CAI intake. LTFT is off up to -13. I used the torque app with a bluetooth obdII scanner I do have a little bit of low speed bucking sometimes.
http://www.ebay.com/itm/Bluetooth-Ca...IAAOSwIIhZhiIS
Old 08-07-2017, 04:29 AM   #9
PRAY
PRAY's Avatar
Drives: 2016 2SS
All of my testing was done with the Roto-fab CAI and the stock GM CAI. I can't say what your trims or fueling will do with any other CAI on the car. As far as I am tracking, the RF CAI is the only one that will maintain the stock AFR curve. You are looking for -LTFT's. Look at your steady state and idle trims for the best average. Off throttle can get skewed with DFCO and other things.
OP- I am a little confused by your post. Why do you think your car is pulling timing? The stock tune in the heat will pull timing and show KR. Mine did it stock. Email or PM me with your questions for a more in depth conversation about what you are actually looking for. Thanks.
