Old 07-24-2017, 12:31 PM   #1
Katech_Jason
Drives: 2015 Z06
Katech CNC porting to your LT1 heads. Killer pricing.
We are now offering CNC porting of LT4 heads as a service if you send in yours. We've also come up with an extremely competitive price on this. Just send in your bare, clean heads and we'll CNC port them for only $499. If you would like us to disassemble, wash and assemble to either stock spec or Katech package specs, just add those items to your cart. Turnaround time is expected to be just a few days but could vary based on shop load.
To order, use the link below:
http://store.katechengines.com/cnc-p...eads-p578.aspx
Katech_Jason is offline   Reply With Quote
Old 07-24-2017, 05:50 PM   #2
JBones81
Drives: 22 ZL1, 18 RS3, 22 M3P
Cool. What are the approx gains on this, for an NA application with presumable intake/exhaust mods?
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2024 Audi RS3
2022 Tesla Model 3 Performance
2018 Audi RS3 - Many mods & e85
Instagram - @JBsCars
JBones81 is offline   Reply With Quote
Old 07-24-2017, 06:38 PM   #3
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Porting the chambers an option?
Old 07-25-2017, 09:25 AM   #4
Jamesg89
Jamesg89's Avatar
Drives: 2019 2SS & 1998 SS
What kind of power are you seeing with your packages with your cam?
Jamesg89 is offline   Reply With Quote
Old 07-25-2017, 01:16 PM   #5
JBones81
Originally Posted by Katech_Jason View Post
600hp at the crank.
600hp na is still legit, in my book
2024 Audi RS3
Old 07-25-2017, 01:23 PM   #6
F1FTY
Drives: 2018 ZL1
600hp at the crank.
Damn that's impressive!
What percentage are you using for drivetrain loss on the Gen 6 so we can figure RWHP with your setup?
F1FTY is offline   Reply With Quote
Old 07-25-2017, 02:05 PM   #7
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
Although its probably less. Id figure 15-18% on the auto 12-15% on the manual
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
Old 07-25-2017, 02:47 PM   #8
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
600 NA is sick. you wont get much better than that
SSTony is offline   Reply With Quote
Old 07-25-2017, 03:37 PM   #9
Franko07
Drives: 17 white 1LE
there are several cam options.... which cam would be the cam mentioned?
and what supporting mods were required other than cam, heads and tune
Franko07 is offline   Reply With Quote
Old 08-04-2017, 08:31 AM   #10
Jamesg89
Jamesg89's Avatar
What are the flow numbers on the porting?
Old 08-04-2017, 08:55 AM   #11
Jamesg89
Jamesg89's Avatar
Flow can be found on the product page here:http://store.katechengines.com/cnc-p...eads-p578.aspx
And in the video above.
Guess I should have looked harder, are there any numbers available below .700", from say .300"-.600"?
Old 08-04-2017, 09:01 AM   #12
Jamesg89
Jamesg89's Avatar
Similar to this
....................PRAY Int......GM Int..../...................PRAY Exh......GM Exh
Dep....Lift..................................../.Dep....Lift...................................
12"....300"...........214..........204.../.15"....300"............180...........165
8"......400"...........273..........264.../.12"....400"............228...........225
7"......500"...........320..........306.../.10"....500"............251...........249
5"......600"...........350..........328.../.10"....600"............258...........258
Old 08-29-2017, 03:09 PM   #13
6spdhyperblue
Drives: 2SS 1LE
Would these be a good match with the stock cam? Also can I have them milled and still run on 93 with the stock cam to improve hp on e85? I am considering just changing the heads for now and get some ls7 lifters in there. Then a cam once I get bored
I guess it would make sense asking for port volume
Trying to get an idea if these would be better paired with a big or small cam
Old 09-01-2017, 09:56 AM   #14
PRAY
PRAY's Avatar
Drives: 2016 2SS
Originally Posted by Jamesg89 View Post
Similar to this
Hey Brother, would you mind editing your post and removing my name from above the flow numbers. I understand that you were just posting the data as an example of lay out and I appreciate you using my model as a good example. The reason is two fold.
1. I am sure Jason doesn't want another vendors name/product displayed in his thread.
2. Without the content of the thread to go with those numbers, they in themselves are very misleading and don't represent my product as they were intended to. This test was not at the industry 28" standard and this test was done against the GM CNC head, not a stock head.
Thanks for your understanding in this matter.
Brett
