Old 07-20-2017, 09:57 AM   #1
Artos
Artos's Avatar
Drives: A10 LT4
For those not using dealer for oil change??
You still using the AC Delco recommended oil filter or prefer another flavor??
Artos is offline   Reply With Quote
Old 07-20-2017, 10:06 AM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Good filters:
The AC delco unit
The Mobil 1 filter
The K&N filter
Old 07-20-2017, 10:08 AM   #3
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Yep
nancygrl is offline   Reply With Quote
Old 07-20-2017, 10:49 AM   #4
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
AC Delco PF64 filter and Mobile 1 5W-30 Synthetic.
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 07-20-2017, 11:07 AM   #5
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
Its all I will use.
speedraider is offline   Reply With Quote
Old 07-20-2017, 02:10 PM   #6
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
To clarify, it takes 10 quarts with filter change...right?
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 07-20-2017, 02:36 PM   #7
JKLNHYD
JKLNHYD's Avatar
For the SS, yes.
"SURSUM AB ORDINE"
Old 07-20-2017, 04:01 PM   #8
Artos
Artos's Avatar
Drives: A10 LT4
Looks as if PF64 may have been superseded to UPF64R...thanks gang. I'll go with mobile 1 oil next time as I had already picked up 10qts of the Valvoline.
Old 07-20-2017, 04:26 PM   #9
Bow Tie Affair
Drives: 6th. Gen ZL1
I prefer Valvoline over Mobil 1. I use Valvoline semi synthetic with Max Life for break in and Valvoline Syn Power with Max Life after break in. Also, i highly recommend a magnetic drain plug.
http://www.camaro6.com/forums/showthread.php?t=493980
http://goldplug.com/
Bow Tie Affair is offline   Reply With Quote
Old 07-20-2017, 04:31 PM   #10
Artos
Artos's Avatar
Drives: A10 LT4
I went with the 5-30 dexos 2 valvoline that Mr. W had posted a pic of some time ago...was thinking I could get away with the 5-40 since it's an oven down here most of the time, but it wasn't on the shelf & not sure when I'll be able to shake loose to track anyway.
Old 07-20-2017, 04:35 PM   #11
Bow Tie Affair
Valvoline 5w30 is Dexos1, Valvoline 5w40 is Dexos2, both of which is perfectly fine.
Old 07-20-2017, 04:45 PM   #12
Artos
Artos's Avatar
Drives: A10 LT4
I stand corrected...that little 'swish' next to the dexos sure looks like the #2 without granny glasses.
Getting old sucks ass...
Old 07-20-2017, 05:29 PM   #13
Bow Tie Affair
I'm right there with you brother. I thought that once as well.
If you haven't already, check the link i posted above showing what i picked up with a magnetic oil drain plug in my 2017 ZL1.
