Old 07-20-2017, 01:04 AM   #1
AlwaysAmerican
AlwaysAmerican's Avatar
Drives: 15 Silverado, 15 Corvette 2LT Z51
Need opinions on tune
Alright, I'm making less power than I should be considering the mods I've done to the car. This is based off my last Dyno
I had the tune pulled and looked at by another shop and according to them the car was wrong and the motor was tuned the same way an LS motor would be and the adjustments made to my transmission and shift points are the same way you'd mess with a 4L60E
Any tuners willing to take a look at the file and tell me how true it is?
I can send a list of the mods done and what specs I can find.
I just need to know if I have to spend the money on a new tune or pay someone here to do it.
Tuned with HP Tuners
2016 Camaro 2SS Mosiac Black Aka-The Reaper
Build Thread- http://www.camaro6.com/forums/showthread.php?t=440437
AlwaysAmerican is offline   Reply With Quote
Old 07-20-2017, 03:39 PM   #2
AlwaysAmerican
Current tune is in Zip folder
Old 07-21-2017, 08:52 AM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
What is your mod List?
www.jannettyracing.com
email tedj@jannettyracing.com
Old 07-21-2017, 09:14 AM   #4
JANNETTYRACING
WOW SMH!
Old 07-21-2017, 09:17 AM   #5
JANNETTYRACING
HOLY CRAP
Old 07-21-2017, 09:30 AM   #6
grampa_ss
grampa_ss's Avatar
Now only if I could read these, maybe I'd know what you're hootin' and hollerin' about.
Can you elaborate for all us simple folk.
Old 07-21-2017, 02:55 PM   #7
AlwaysAmerican
Mods are (from top to bottom)
Ported Throttle Body
MSD Atomic Air force Intake Manifold
Heads have been ported and polished
Comp Cams Camshaft with a 34% fuel lobe ( I can get the specs when I get back to the house)
Callies Forged Lower
Diamond Racing Pistons (I'll see if I can find the specs on those as well)
D-1 Pro charger with 9lbs of boost
Snow Methanol Kit
Running on 100 Octane right now
Stock injectors and HPFP. Was told it would support up to about 750rwhp, have LT4 hardware in the garage. Car wouldn't run with LT4 hardware after procharger was installed
I'm assuming by your reaction, the tune is in fact wrong
Old 07-21-2017, 02:57 PM   #8
AlwaysAmerican
Basically car wasn't tuned the way a Direct Injection motor should be. Same mindset on tuning a LS motor.
Even the adjustments made to my trans has me wondering...
In short... A lot of time and money spent, car isn't doing what it should be
Old 07-21-2017, 03:18 PM   #9
JANNETTYRACING
Snow Methanol Kit
You can reach your own conclusion from the evidence.
There is no reason the car should not start and run with LT4 pump and injectors, I just did mine 2 weeks ago and the car started and ran pretty good just to drive around to the dyno bay.
The tune must be set up for this hardware.
There is no way I would try and run 750 RWHP on stock LT1 fuel hardware.
We stop at 575 RWHP.
Granted your Meth system can be used for fuel supplement but that is dancing on the landmines.
Did you increase the cubic inches?
Old 07-21-2017, 03:30 PM   #10
AlwaysAmerican
I did, it's a 416 now. Sorry thought I stated that, hard to see on mobile sometimes.
Hell at this point I'd be happy with 575 RWHP, send it across Barrett Jackson and move on to a ZL1
But the way it feels now, is just WRONG on so many levels..
Problem will be finding someone in town that can do the tune, I've heard of one person, but problem is a lot of the shops around here talk shit about each other.
Old 07-21-2017, 03:43 PM   #11
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
...I'm assuming by your reaction, the tune is in fact wrong
Just going off what Jannetty posted, the MAF scaling is so far off a stock LT1 it's irrational. Not to mention the shaping smoothness is pathetic. The timing table is also janky.
Please go to a real tuner like Jannetty and get your tune sorted out. It kind of amazing your car runs at all. If I were you I'd garage it until at least a safe base tune can be sorted out.
Edit - just DL'd your tune. LOL your cam phaser is turned off. DOH. Looks like they also messed with your idle, and ironically the cam angle mapping. Also, they really messed with your pedal mapping. Is the pedal really sensitive feeling? Yea there's a whole bunch of strange things going on here. Kind of confused how whack it is.
Old 07-21-2017, 07:28 PM   #12
AlwaysAmerican
Yea, peddle is sensitive as hell, 10% throttle almost feels like 50%
