Old 07-19-2017, 12:04 PM   #1
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
PDR video - Stock A10 ZL1 1/4 run
My very first run down the strip.
11.92@122.9 - Using Launch Control
https://youtu.be/RMUl2ZNgmbY
My only other run was a 11.83@123.5, but forgot to hit record.
DA ~2500
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 07-19-2017, 03:22 PM   #2
Jeffro19
Jeffro19's Avatar
Cool video! In my home town.
Old 07-19-2017, 03:57 PM   #3
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
I love seeing PDR videos. The higher gears only drops to 5500 rpm after the shift which is good, but I am surprised how much the lower gears are short shifted in the A10.
DrkPhx is offline   Reply With Quote
Old 07-19-2017, 04:43 PM   #4
thompstl1
thompstl1's Avatar
Drives: 2017 A10 ZL1
I haven't run mine through the 1/4 yet, but I'd be happy with that!
Clear Bra, Tint, Splash Guards, Ceramic Coating, Painted Spoiler and Rear Views
thompstl1 is offline   Reply With Quote
Old 07-19-2017, 05:07 PM   #5
Busted43
Busted43's Avatar
Drives: 2018 zl1,A10,16 GLC300
Cool vid, can't wait to get mine and give it a run.
2018 ABM,A10
Kooks 2” headers no cats, NW 103 Tb, Kong ported blower with 2.31 pully, Elite E2x catch can, Cordes under hood expansion tank, Flowmaster axle back, Rotofab dry filter,Mustang Dyno # 647whp/674wtq.
Busted43 is offline   Reply With Quote
Old 07-19-2017, 05:41 PM   #6
Blown355
Blown355's Avatar
I was told the reasoning behind that was because the RPMs come up so fast in the lower gears that if it didn't short shift you would bounce off the Rev limiter.
Sounds plausible.
2017 ZL1
A10
Redhot with stripe
Old 07-19-2017, 05:43 PM   #7
Blown355
Blown355's Avatar
I'm itching to get back out there, but it's been so dang hot. 102 today!
2017 ZL1
A10
Redhot with stripe
Old 07-19-2017, 05:51 PM   #8
GarnetRedJuan
Drives: 2017 garnet red zl1 2022 AT4 HD
Sounds plausible.
I can confirm that in 1st, if you don't shift below 6k manually even, you will most likely bounce off the limiter, car will cut power, and you will be slower.
GarnetRedJuan is offline   Reply With Quote
Old 07-19-2017, 06:16 PM   #9
IneedAZ
IneedAZ's Avatar
DA ~2500
Looks like you had traction control still on. Think it hurt ur time if it in fact was. I saw the light come on.
Old 07-19-2017, 08:25 PM   #10
Blown355
Blown355's Avatar
Yeah, left the nannies on. It was my first time at the track with this car. Wasn't brave enough to turn everything off, before I even made the first car payment.
2017 ZL1
A10
Redhot with stripe
Old 09-17-2017, 10:57 PM   #11
DragRacerX
DragRacerX's Avatar
Drives: 2017 ZL1 A10 HBM & 2012 2SS M6 IBM
What settings did you choose in Launch Control? Somewhere I read (or was told) you could use Launch Control in Sport or Track Mode. I have only been able to configure it in Track Mode. I have tried Surface Settings of Dry, Sport 1, & Sport 2. I have tried Launch RPMs of 1600, 1700, & 1800. I have tried Slip from 8.0 to 10. Unfortunately I didn't keep records of the combinations and their results (was having way too much fun).
2017 ZL1 Hyper Blue Metallic, A10 Trans, CF Hood, NAV, PDR, Sunroof, aFe Momentum GT CAI, Vmax Motorsports TB, ARH LT CAV8-16200300FSQWC (Daily Driver)
576 RWHP/575 RWTQ
2012 2SS/RS IBM Technostalgia LED taillights, Magnuson TVS2300 & 3.40 Pulley,
Vengeance Racing VRPD-2 Cam Kit, ZL1 Fuel Pump, Injector Dynamics ID850 Injectors, Forced Induction Interchiller,
Cold Air Inductions CAI, BBK 40210 LT Headers & Free Flow Cats, MBRP S7022409 T409-Stainless Steel
3" Dual Cat Back Exhaust System, Lingenfelter ZR1 Dual Disc Clutch Kit, ZL1 Brake Kit Rotors & Calipers
628 RWHP/596 RWTQ / A.C.E.5
DragRacerX is offline   Reply With Quote
Old 09-18-2017, 06:32 AM   #12
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Very strong. My slightly modded 2SS runs 12.2 at 114 in those conditions and 11.8 in a good DA at 118. Just shows how fast the ZL1 is at 122/123 MPH in the heat. You'll crack 128/129 with a good DA and run mid 11's at least.
Old 09-18-2017, 07:33 AM   #13
Blown355
Blown355's Avatar
I used Track mode and Dry for both runs. I get consistent 3.7 0-60mph on the street with those settings, but only managed a 3.9 at the track. Go figure.
I just wanted to see what could be had by using LC. I won't be using it in the future.
Everyone running sub 11.5 times are not using launch control.
2017 ZL1
A10
Redhot with stripe
Old 09-18-2017, 09:36 AM   #14
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
I've yet to try launch control at the track, but I think you could get it to work decent if played with enough. I'd recommend setting it to race if you use LC again. There's less computer interference and more power available in Race according to the manual and my road testing.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
