Old 07-19-2017, 06:23 AM   #1
McBrayer
Drives: 2017 ZL1
Brake pad REPLACEMENT for less dust
AS with a lot of ZL1 owner, I am tired of fighting brake dust. The brakes on these cars a freaking awesome, but the dust and the dust and the dust and then more dust.
There are several threads on here regarding replacement pads that preform as well as stock but do not create nearly as much dust. These threads are spread out and hit or miss.
How about a fresh thread that list pads KNOWN to preform nearly as well as stock and make a lot less dust.
THANKS!!!!
McBrayer is offline   Reply With Quote
Old 07-19-2017, 08:21 AM   #2
soceur77
Drives: 17 NFG ZL1 17 GTR 22 RS6
sub'd
soceur77 is offline   Reply With Quote
Old 07-19-2017, 08:29 AM   #3
Johnnysflooring
Drives: 2017 Nightfall Gray M6
sub
Johnnysflooring is offline   Reply With Quote
Old 07-19-2017, 09:26 AM   #4
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
OK, I have had Power stop pads on my C6 Z06, C7Z06 and 2017 zl1. Never had any problems, the dust is cut down at least 90%. part # for the 2017 zl1 are z26-1835 for the front and z26-1053 for the rear.
speedraider is offline   Reply With Quote
Old 07-19-2017, 09:32 AM   #5
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
Ditto....Power Stop pads will make you happy
aka Reckless is offline   Reply With Quote
Old 07-19-2017, 09:53 AM   #6
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
Get the wheels ceramic coated. It helps tremendously with cleaning the dust off. I had mine done for $25 a wheel. I apply some wheel and tire cleaner, wait 30 seconds, agitate briefly and then rinse off and the wheels look brand new. All 4 wheels take less than 5 minutes start to finish. With a strong enough stream of water the dust can be rinsed off too but for me agitating with a brush gets a better result.
djfury05 is offline   Reply With Quote
Old 07-19-2017, 09:54 AM   #7
JeromeS13
Drives: 2017 1SS/1LE
PowerStop Z26
Caveat: DON'T USE THEM AT THE TRACK.
Old 07-19-2017, 11:37 AM   #8
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
Once a week I get out my power washer, and just hit the rims with plain water. Cleans them up so far just perfectly. The black dust residue just rolls off down the driveway.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 07-19-2017, 11:45 AM   #9
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
+1
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 07-19-2017, 11:51 AM   #10
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
On the 5th gens, you could get the Cadillac versions of the pads and do much better on dust, but you weren't supposed to take it racing. I would assume that is still true but somebody would need to confirm.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 07-19-2017, 12:02 PM   #11
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
+1
Friend (kracka) with c7 z51 switched over to Z26s, fantastic results. Zero dust compared to stock. I ordered the same ones, got delivered today and will be doing a lot of flushes soon and plan on installing them when I do that soon.
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 07-19-2017, 12:20 PM   #12
jbp8653
jbp8653's Avatar
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto
My Powerstops are on the way. Should be installed by the weekend.
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv.
1952 C3100 resto-rod. LS6, 4L60e, 228R cam
jbp8653 is offline   Reply With Quote
Old 07-19-2017, 02:44 PM   #13
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Thumbs up
I had the Hawks on my 2012. Excellent. Cost was about $430 all fours corners.
These powerstops are only running about $75 front and $63 rear. Total will be less than $150 all around.
Whats the opinion on this in general? The Powerstops seem like a steal. The reviews on them are generally great.
Also, where do you recommend sourcing?
htron50 is offline   Reply With Quote
Old 07-19-2017, 03:05 PM   #14
jbp8653
jbp8653's Avatar
126.00 Shipped from Summit Racing
