Old 07-18-2017, 03:05 PM   #1
Deuce22
Drives: 2017 Camaro ZL1 / Black / Manual
Check your oil level!!!
Based on another thread I saw here I checked my oil level today - car is at 2,650 miles. It read low - just at the very bottom of the dipstick hash-marks.
It took 3 1/2 quarts!!
Personally I don't mind performance engines eating oil, but I'd hate to see someone have a problem. Check your oil level regularly!!
Deuce22 is offline   Reply With Quote
Old 07-18-2017, 03:21 PM   #2
RedCamaroZL1
RedCamaroZL1's Avatar
Checked mine today after seeing the other thread. 1150 and reading full on the dip stick. Haven't changed oil yet. Waiting until 1500 miles to change it.
2017 Camaro ZL1 Red Hot A10, PDR, Nav, ECF
RedCamaroZL1 is offline   Reply With Quote
Old 07-18-2017, 03:28 PM   #3
Infern0
Bring It
Infern0's Avatar
Drives: In Between
I'm surprised to see that much tolerance measured in the hashmarks (assuming you filled until the top of the marks?). 3.5 quarts!
Checked based on the other thread as well and mine was at the top. I meant to check right after the oil change itself. Though I did look at the quantity they put on the invoice just to make sure that at least had the correct amount.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 07-18-2017, 03:32 PM   #4
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
These engines are crazy in how different they are from engine to engine (both the LT1 and LT4). Some eat oil, and some don't. I have about 3,500 miles on mine since the last oil change and that includes 4 track days and 3 auto crosses and it is still reading full. It burns no oil. Others go through oil like crazy.
Eric SS is offline   Reply With Quote
Old 07-18-2017, 03:41 PM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Do the V8's have a low oil level light on them? My V6 does. Because it's gone off when I was about 2 quarts low as I changed the oil…
Surprised one did not go off here......
Old 07-18-2017, 03:50 PM   #6
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Good point. The link here is the "other" thread which OP got a light only being 2qts low. Also surprised that 3.5 low didn't produce a light. Still curious that the bottom of hashes to the top of hashes is 3.5 qts.
http://www.camaro6.com/forums/showthread.php?t=501726
Old 07-18-2017, 04:04 PM   #7
Deuce22
I did not get a low oil level light - which is concerning. I'll be making a habit of checking it regularly...
Old 07-18-2017, 04:41 PM   #8
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
My first oil change was at 2,000 miles with no oil loss. If I lost 3.5 qt in 2,600 miles I would be concerned, to me that's unusually high even for a motor that's not broke in yet. Of course that's assuming it was full when you purchased it. Food for thought!
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 07-18-2017, 04:42 PM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Between the hash marks is not 3.5qts...more like 1-1/2 qts.
Old 07-18-2017, 08:11 PM   #10
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
It is also surprising to me the amount of variation between cars. I've done 2 track days and an autocross event and having burned a drop of oil.
Inspector 17 is offline   Reply With Quote
Old 07-18-2017, 09:27 PM   #11
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
This is when the break in theory comes into play.
Evolvedx27 is offline   Reply With Quote
Old 07-18-2017, 10:03 PM   #12
Eric SS
#becauseracecar
Eric SS's Avatar
I'll add to my post above (I don't burn any oil) that although I didn't drive it too hard until 1,500 miles I bought it with like 130 miles on it so I'm sure it was beat on pretty good before I got it. I've never been one to baby an engine from the beginning and subscribe to the "drive if hard from the beginning" theory.
Old 07-18-2017, 11:17 PM   #13
CarFlow1
Drives: 2017 ZL1 A10 (Summit White)
Getting my first oil change tomorrow, this should be interesting as I would like to know if my vehicle has burned a lot of oil. I have about 60% oil life though
CarFlow1 is offline   Reply With Quote
Old 07-19-2017, 08:12 AM   #14
DFW1LE
DFW1LE's Avatar
On these oil changes, I would think its appropriate to put in 9.5 qt and check level and only add more if needed or do you put in all 10 its and hope it doesn't go over?
