Old 07-16-2017, 10:45 AM   #1
bobshannon22
bobshannon22's Avatar
Drives: 2016 camaro 1ss
Where's the limit of stock fuel system with e85?
At FBO/E85 I had about 500rwhp. I'm adding heads/Cam and some other BS. At what point will the stock fuel system not be able to keep up with e85? My Cam has the +32 fuel lobe (TSP VVT-2)
In short, can stock fuel system be e85 for a H/C//I/FBO car?
2016 1SS (M6) Kooks headers and exhaust, pray ported MSD/TB, JLT CAI, JLT catch can, TSP heads/VVT-2 cam, E85, Centerfirce clutch, g force axels and DS, most of what BMR makes, blah blah blah
bobshannon22 is offline   Reply With Quote
Old 07-17-2017, 05:43 AM   #2
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
From my understanding, 575-600 is your ceiling.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 07-17-2017, 07:40 AM   #3
bobshannon22
So roughly the same for e85 and 93?
Old 07-18-2017, 06:04 AM   #4
Darth Martel
Darth Martel
fuel delivery is fuel delivery whether you're running e85, 93, or rocket fuel
Old 07-18-2017, 06:14 AM   #5
DSX Tuning
Drives: 2019 Corvette ZR1
Because of the need for more volume of fuel to make power on E85, you're probably going to be maxing the system out around where you'll sit. The bigger fuel lobe will help for sure, but you'll want to look into a low side pump upgrade. I'll have my low side kit available shortly.
DSX Tuning is offline   Reply With Quote
Old 07-18-2017, 08:13 AM   #6
bobshannon22
I guess I'll find out. If I need one I'll go with you guys forsure!
If you need a test monkey I think my car would be perfect with the mods
Old 07-18-2017, 11:05 AM   #7
PRAY
PRAY's Avatar
Drives: 2016 2SS
You can get a ZL1 in tank pump now as well. Drops right in. I will have to check the retail portion of my receipt but I am sure it is under $300. I would say that you should be able to get to 550-575rw with the lobe and the ZL1 on full E85. We just tried adding E85 to a C7Z we were doing. It makes 640/670rw on pump. We only go to E40 before we lost rail pressure and the car really didn't make any more power. That was on the stock Z fuel system with no cam lobe. I am sure the lobe and in tank pump will cover down on just about any stock displacement motor. Just remember that it takes 30% more E85 to make the same power as pump. That is why meth is so attractive.
Old 07-18-2017, 11:18 AM   #8
Darth Martel
Darth Martel
you can get a ZL1 in tank fuel pump for $162.50 (not including shipping if there is any)
thatGMpartsguy
Old 07-18-2017, 11:23 AM   #9
bobshannon22
How's the instal for the pump? Any write ups?
For that price where can I get one?
Thank you guys for the good info!
Old 07-18-2017, 01:30 PM   #10
bobshannon22
So after some research I have came to the conclusion that even if I'm short on fuel a LT4 pump wouldn't be the best choice. I guess the lash caps (needed for me +32 fuel lobe cam) can force the pump to basically sheer itself.
The vette guys have had plenty of issues with it, but only with LT4 pump, not LT1.
Old 07-19-2017, 09:27 PM   #11
Hyperlinkblue
Drives: 2017 1ss m6. Blue.....
You need to choose the correct lash cap. And also thats for the high preassure fuel pump, not the low preassure fuel pump, there refering to the low preassure fuel pump that is in the gas tank to supply the high presssre pump which sits under your intake manifold.
This will help on selecting the correct lash cap for the corespondig HPFP.
https://www.corvetteforum.com/forums...learances.html
Hyperlinkblue is offline   Reply With Quote
Old 10-01-2019, 04:54 PM   #12
Vrodviddy
Drives: 2018 Camaro ss
This very true. Most cam kits include the .080 lash cap. This is way to big. Need to get the .060 and even then shave it down a bit. Any larger the .060 and your pump will sheer the bolts and fly right of the engine.
Vrodviddy is offline   Reply With Quote
