Old 07-15-2017, 10:46 AM   #1
Electric
Electric's Avatar
Drives: 2018 1SS 1LE
Any way to reset fuel map for 93 octane?
Hello all! Just traded my 15 SS 1LE for 18 SS 1LE. The only problem is that the dealer "while preparing the car for my arrival" put a full tank of 87 in it.
Since than I have burned off all remaining 87 and put 93 in. However, the car still has some drivability issues when just getting of the line. Also, throttle reponses seem to be more sluggish than on the other Camaro that I test drove.
Is there anything I can do to reset the computer, so that it forgets that it had 87 in it?
On the 5th gen there is a fuse you can pull. Is there anything like that on the 6th gen?
Electric is offline   Reply With Quote
Old 07-15-2017, 01:08 PM   #2
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
I've not heard of anyway to do it yet, but maybe some others have. If not I would take it back to the dealer and demand they reset it since they are the ones who caused it.
Old 07-15-2017, 02:13 PM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Just keep driving it with 93 in it. The ECU will trim back to normal with time.
Old 07-15-2017, 02:47 PM   #4
mitch03
Drives: 2016 Camaro 2SS White
I would disconnect the battery for a couple of hours. That should reset it.
mitch03 is offline   Reply With Quote
Old 07-15-2017, 03:40 PM   #5
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Takes the ECU 150 miles to get all parameters reset after a change of things (mods, tune, fuel, airflow etc).
Dealership putting 87 is absolutely horrible. What kind of idiot puts non-premium gas in a car that REQUIRES premium? I hope they did not seriously cause issues with the injectors, engine itself, fuel pump and any fuel related with the engine... While it's not as bad as putting diesel in a gasoline vehicle but what they did CAN ruin the car... LT1 already hates even non top tier premium... I cannot imagine how it is with 87...
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 07-15-2017, 04:54 PM   #6
Electric
Electric's Avatar
I really don't think it should damage anything. Especially considering I was keeping it in the mid range under light load, to ensure there's no detonation.
Owners manual actually allows 87, just recommends against it.
But yea, it was really running like crap, and apparently it's still recovering. I think so far I drove about 120 miles on 93.
Old 07-15-2017, 05:59 PM   #7
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Good thing you have a 3 year bumper-to-bumper warranty!
CruzySS is offline   Reply With Quote
Old 07-15-2017, 10:24 PM   #8
Tr6
The Dogfather
Glad you were very smart about it, kudos! 30 more miles or so ECU will be back to normal. The car should already feel so much smoother and it will be back to how it should be stock once you hit 150.
Build thread HERE!
Old 04-29-2018, 08:57 AM   #9
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
Why?
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
Old 04-29-2018, 09:44 AM   #10
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
My dealer did the same thing even with asking them to either put 93 in it or leave it empty. They only care about spending as little money as possible. My car is fine. Just babied it while the 87 was in the tank.
Pollock is offline   Reply With Quote
Old 04-29-2018, 09:46 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by wildchevy View Post
Why?
Just another misinformed poster is all. The fact is you can run 87 octane in these engines, but It's not something I would do. The ECM has low octane spark tables, so it's not going to blow up.
Old 04-29-2018, 12:32 PM   #12
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
Yea, there was mention of damage to injectors, fuel pump, etc. None of those care what gas runs through their respective systems, so no harm there. It's about controlling pre-detonation, so running smooth and low stress by not pushing on it, you will be fine. As others have said, the manual says you can run 87, it just isn't recommended.
Now stale fuel, contaminated fuel, that is a different situation.
BrianL is offline   Reply With Quote
Old 04-29-2018, 01:34 PM   #13
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
fill it up with 95 octane
Old 04-29-2018, 04:18 PM   #14
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Your over thinking it. I put a tank of 87 by mistake in. No real difference.....
