OMWTFYB
Drives: ZL1 Join Date: Sep 2011
2017 1LE stuck in reverse
Today while backing into a parking spot, I went to put car in neutral and was stuck in gear.
Turned car off and on and let it roll forward and it came out of gear. Went through all gears was fine. Looking for insight if something I should worry or look into or dismiss as a fluke |
![]() Drives: Black 1SS 1LE Join Date: Jul 2017
If it ever happens agin scroll threw your gauges and check the Transmission temp. See if its higher than normal.
OMWTFYB
Gotcha
Sent from my iPhone using Tapatalk |
IG @HOST1LE_gen6
![]() Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
That video doesn't show a car stuck in reverse.
If the issue is with the reverse camera, it does take time for it to turn off like all cars with reverse cameras -that's a universal technology. She doesn't allow any time for the shifter to stay out of reverse for the camera view to disappear. The beginning of the video shows the display, shifter, and camera in reverse. Then she quickly goes between reverse and neutral. What does this video even show? |
OMWTFYB
It's my car and I'm a HE...what the video shows is the I'm not able to put the car in neutral...shifter is stuck in the gate
#7 |
Sorry... Nice nails...
#8 |
@SS_1LE
Drives: 2017 SS 1LE Join Date: Mar 2017
Lol.
Almost seems like an issue with the reverse lockout that allows you to go into reverse after the car is stopped, but somehow not allowing you to get out of the reverse gate. It looks like you are able to get out of the reverse gear, just not out of the gate.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S |
#9 |
OMWTFYB
^^correct
I eventually get out of gear but while in neutral I have a hard time putting in gear. Once in gear the car is fine. Also, not able to wiggle it in neutral Sent from my iPhone using Tapatalk |
#10 |
![]() Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
First question do you have skip shift elliminator? If you do take it off. It caused my car to not be able to shift out of neutral several times. I didn't believe it until I took it to the dealer and luckily had a cool service tech that told me he's ran into this several times on the Vette platform. Removed it and it hasn't done it since.
#11 |
OMWTFYB
Car is tuned so SS is turned off
#12 | |
Scientific negotiator
Drives: 2019 Grand Sport Join Date: Mar 2017
Does your 1-4 warning still come On? If so, does the solenoid stay completely open (no lock, no rough feel going into 2nd)? When you run it hard, is the 1-2 shift smooth? How about 5-6?
2019 Grand Sport M7
2018 ZL1 1LE 6MT 2017 SS 1LE 6MT . Matthew 25:40 ΜΟΛΩΝ ΛΑβΕ |
