Old 07-09-2017, 06:46 PM   #1
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
The use of a Lash Cap finally explained!
I've been pondering the concept of the use of a lash cap and could never get a clear idea of when and/or how to use a lash cap to increase fueling. Finally, finally found a clear description on how to properly fit up lash caps!!
https://www.corvetteforum.com/forums...learances.html
Fyreant has a great set of "how to"s in this forum of which I am using like a series of classes on the LT1 engine. Kudos to Fryeant for all of his hard work on the corvette forum.
Atomic Ed is offline   Reply With Quote
Old 07-09-2017, 07:48 PM   #2
glenB
Drives: Chevrolet Camaro SS
Good read, thx
glenB is offline   Reply With Quote
Old 07-09-2017, 08:01 PM   #3
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
Thanks for the link. It makes me wonder why some companies say even with the 32% lobe you dont need a lash cap.
Turbo_RORO is offline   Reply With Quote
Old 07-10-2017, 04:05 AM   #4
80sMetalDude
80sMetalDude's Avatar
Drives: .
Thanks that helped me visualize what all this lash cap talk was all about for a noob.
80sMetalDude is offline   Reply With Quote
Old 07-10-2017, 07:33 AM   #5
DFW1LE
DFW1LE's Avatar
I had come across that post on Corvette Forum several days ago. Its a good explanation, but ensuring the lash cap gets installed correctly by the shop doing one's build would still be a worry for me. And how many shops install them without using the tool.
Old 07-10-2017, 09:54 AM   #6
Atomic Ed
A valid point, but at least now you are armed with some knowledge. If you are thinking about having a shop install a lash cap, say, with a cam kit, you can query them on how they plan to approach the installation and see if they use this approach.
I'm planning on a major tune later on. Even though the local speed shop has a great reputation regionally, I still have a laundry list of questions I plan to ask when I get the tune done. In particular, how do they plan to approach a possible fueling issue if they run out of headroom on fuel delivery. A lash cap will be part of that discussion.
