Old 07-09-2017, 01:30 PM   #1
thinkingcamaro
Drives: 2017 Summit White Camaro 2SS
Replacing brake pads, want to confirm...
The brake dust from the stock brake pads is just too much, so I'm going to replace the pads with Power Stop pads. I want to make sure I'm getting the correct ones. I have the 6 piston front brake kit on my 2SS.
Z17 Evolution Plus
17-1405 (front)
17-1718 (rear)
I was looking at Amazon and I'm unclear as to whether I order one for the front and one for the rear, or do I order two for the front and two for the rear? The 1405 pic shows two pair and the 1718 pic shows one pair.
thinkingcamaro is offline   Reply With Quote
Old 07-09-2017, 06:30 PM   #2
enzia35
Drives: '16 Garnet Red 1SS
Usually when buying pads, one box should be enough for each axle. But those are some really cheap prices for 4 pads...
I'd just buy one of each.
'16 Camaro 1SS
'18 Miata GT
Old 07-10-2017, 03:22 PM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Those are the correct pad sizes for the 14.6" 6-piston front and normal SS rear, but IMO that pad compound isn't what I'd go with. Do the Z26's, that's what I run on the street. There's virtually no brake dust, and the pedal feel and initial bite are nearly the same as the stock Ferodo HP1000's.
Don't let the "extreme performance" name scare you away. They're most definitely a street pad.
https://www.amazon.com/Power-Stop-Z2...ower+stop+1405
https://www.amazon.com/Power-Stop-Z2...ower+stop+1718
Old 07-10-2017, 05:49 PM   #4
enzia35
I was going to suggest going to the z26 too.
'16 Camaro 1SS
'18 Miata GT
Old 07-10-2017, 06:39 PM   #5
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
+1 to the Z26 pads. Virtually no dust compared to the stock pads.
Also, get one of these to make it super easy.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 07-10-2017, 08:24 PM   #6
thinkingcamaro
Thanks everyone! I appreciate the assistance.
Old 07-20-2017, 03:07 AM   #7
dwill8335
Drives: 2017 Camaro ZL1 Ice Metallic A10
I toasted those pads (powerstop) in one track day..... lost brakes after 8 laps and I had bedded per manufacturer went back to stock for now no problems, running SRF fluid shopping for my next pads now....... those pads imho were garbage
dwill8335 is offline   Reply With Quote
Old 07-20-2017, 05:29 AM   #8
Bluecyclone
Bluecyclone's Avatar
Drives: 2014 Cyclone mustang
Mercy, toast in 8 track laps? I'd always heard PowerStop pads were great. This is the 1st. post I've read where they did not perform.
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/
Bluecyclone is offline   Reply With Quote
Old 07-20-2017, 08:44 AM   #9
Chez
Chez's Avatar
Were those the Z26 or Track Day pads? I use Z26 for daily use and the Track Day pads for HPDE and haven't had issues.
Chez is offline   Reply With Quote
Old 07-20-2017, 10:36 AM   #10
Curr
Curr's Avatar
So you used street / non-track pads on the track and they didn't perform?
Color me shocked...
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Old 07-20-2017, 10:45 AM   #11
Ponyeatr16ss
retired badass
Ponyeatr16ss's Avatar
Drives: 2016 2SS M6
Send a message via AIM to Ponyeatr16ss Send a message via Yahoo to Ponyeatr16ss
Color me shocked...
2016 2SS M6 Black
Kooks 2in headers/full exhaust, Hurst short shifter, Dsx E85 kit, BMR solid engine mounts.
Retired USMC
Ponyeatr16ss is offline   Reply With Quote
Old 09-01-2017, 01:38 AM   #12
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
The z26 will work for the 1ss as well correct?
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
Old 09-01-2017, 09:09 AM   #13
TJay74
If you get the correct ones, yes.
Old 09-01-2017, 04:07 PM   #14
solobaric
solobaric's Avatar
Sorry, I meant the 1405 and 1718 respectively
2001 Ford Lightning
