Old 07-06-2017, 09:10 PM   #1
Cmyskill
17 ZL1 what a car....
Cmyskill's Avatar
Drives: 2021 M S PLAID, 2017 ZL1 A10 White
Send a message via AIM to Cmyskill
ZL1-MRR-M017 Nitto NT01's W/315's and 285's
Name:  12 inches plus.jpg
Ok, I finally found time to add my MRR M017 in gloss black to my A10 ZL1. I chose to go with the Nitto NT01 in a 315x30x20 in the rear and a 285x35x20 in the front. The rear tires fit perfect with NO rubbing issues. However, the front was a different story, and did rub on the shock tower. I added a 3mm Spacer and no rubbing so far, I really hate the fact that I had to add it.... grrr
As for the ride it feels about the same as the stock tires but there is a bit more road noise, not a lot but definitely noticeable. After a few minutes driving I completely forgot about it and I just focused on the sound of the engine.
As for Traction, the Nitto NT01's stick big time. Hitting 3.3 seconds 0-60 is quite common and the tires and wheels are my only performance mods to date. My best 0-60 time on stock tires was 3.5 seconds. (on the street not the track)
The slightly larger tires fill the fender-wells pretty good with out lifting the car to much. From the back the tires look super aggressive and give the car an amazing stance. The Rear tires measure about 12.3 inches from outside to inside.
Now, I am trying to decide if I should lower the car? I really do not want to make the car a pain to drive and I know adding lowering springs sometimes leads driving issues.
Also, a special thanks to Paul at PK Auto design for the wheels, tire setup and they were perfectly mounted and balanced.
2017 ZL1 -- WHT - A10 - PDR - NAV
Mods: Kooks 2", Lingenfelter 9.17” 18% Pulley, CAI, E85 sensor, and Interceptor Wide-band & Gauge with Pod, 180 Thermostat, BMR Rear suspension parts.
Cmyskill is offline   Reply With Quote
Old 07-06-2017, 09:13 PM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Very nice.
Love it.
Old 07-06-2017, 10:15 PM   #3
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
But Bradford... the rear pokes!!!!
seanblurr is offline   Reply With Quote
Old 07-06-2017, 10:52 PM   #4
BradfordCamaro
SABIO
I see that now.
Weird.
Is ZL1 offset different? Why would it poke out like that?
It is a standard 20x11 +43 offset. Unless the O.P added a spacer?
Old 07-06-2017, 11:43 PM   #5
Cmyskill
Cmyskill's Avatar
It does seem to fit a little different than normal, But the top of the wheel is dead flush with the fender when looking from the front. I used a ruler to make sure. No spacers on the rear at all and they are normal back spacing from MRR. Here is a pic from the drivers and passengers door looking back. Also, If you get really sticky tires, Rock guards are a must...
Old 07-07-2017, 12:15 AM   #6
AxiomVerge
AxiomVerge's Avatar
Drives: 2017 Mosaic Black M6 1SS Vert
Attachment 883423
Why do sticky tires throw up more rocks? What rock guards do you use?
Sent from my SM-G935T using Tapatalk
2017 Mosaic Black 1SS Convertible M6 / MRC / NPP
Magnuson Heartbeat, Rotofab
Previous:
2008 Corvette Convertible
2007 Pontiac Solstice GXP
AxiomVerge is offline   Reply With Quote
Old 07-07-2017, 12:41 AM   #7
Cmyskill
Cmyskill's Avatar
Yes, way more rocks. Every road I drive on, I can here them hitting the car. It is like four times worse than stock tires.... rock guards at zl1addons.com
Old 07-07-2017, 11:17 AM   #8
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I was only giving BC a hard time. Perhaps it has to do with the 315, it looks as if the sidewall is ballooned out a bit past the edge of the rim.
Old 07-07-2017, 11:31 AM   #9
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
looks great! im not really a big fan of the ZL1 wheels. those 1le wheels set it off just right.
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 07-09-2017, 03:49 PM   #10
MIAMI2SSRS
MIAMI2SSRS's Avatar
Drives: 2016 Black 1SS Camaro
It look awesome!!! Congratulations.
If you don't mind me asking, did you install the entire setup yourself or you took to a commercial place to get it installed? If commercial, where?
Main concern is the 3mm spacer. I am perfectly OK with using it I just can't install it or the wheels and tires for that matter.
Thanks.
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.”
Albert Einstein
MIAMI2SSRS is offline   Reply With Quote
Old 07-09-2017, 04:16 PM   #11
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Surprised that the front rubbed and that the rear didn't at all without spacers...
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 07-09-2017, 05:56 PM   #12
Old 07-09-2017, 06:08 PM   #13
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
I think for the front rubs because of 35 series tire instead of OEM 30 series 285.
OP, that car is beautiful!
JRL1LE is offline   Reply With Quote
Old 07-09-2017, 06:13 PM   #14
BowtieRocket
Gonna be a great setup! I plan on doing the same with my MRRs on the SS. Good to know a spacer is needed.
m017, mrr, nitto, nt01, zl1
