Old 07-04-2017, 04:39 PM   #1
CarFlow1
Drives: 2017 ZL1 A10 (Summit White)
ZL1 Trunk issue
Just went outside to my car and attempted to open the trunk via the remote. Strangely, it isn't opening and I tried doing it from the inside but it doesn't look like that is working either. Any one else experienced this issue by any chance?
CarFlow1 is offline   Reply With Quote
Old 07-04-2017, 04:41 PM   #2
IneedAZ
IneedAZ's Avatar
Is the car in valet by chance?
Old 07-04-2017, 04:44 PM   #3
trident
No Hope
trident's Avatar
Drives: 2017 ZL1 Black Coupe, 2017 Z06,
Emergency trunk lever
The other day, I unhooked the battery and couldn't open the trunk so tried the emergency handle in the trunk and it did not work either. I guess the emergency handle requires power as well? (I know it was stupid)
trident is offline   Reply With Quote
Old 07-04-2017, 04:46 PM   #4
Dethsupp0rt
Drives: None
How about the button above the license plate?
Dethsupp0rt is offline   Reply With Quote
Old 07-04-2017, 04:48 PM   #5
CarFlow1
Doesn't work either. Lights flash and that is all while the trunk stays closed.
Old 07-04-2017, 04:49 PM   #6
CarFlow1
Valet mode? Nope not at all.
Old 07-04-2017, 04:51 PM   #7
CarFlow1
For a car this expensive we expect things like this to just work without any issues. The emergency break shouldn't require power just to open it, if this doesn't work today I'll have to take it into the dealer tomorrow.
Old 07-04-2017, 05:03 PM   #8
CarFlow1
I think I've identified the cause of the issue, the emergency trunk latch was loose. This caused the car into thinking that the trunk was open when it looked as if it wasn't. I opened the trunk from the inside and closed the trunk harder (after ensuring the emergency latch was secured first)
Old 07-04-2017, 06:51 PM   #9
Kanine
Kanine's Avatar
Drives: 2017 Camaro ZL1 Hyper Blue
Mine does it all the time. If it doesn't open press down on the trunk and hit open on the keyfob again and it will open. I think the wing is heavy so it doesn't pop correctly.
Kanine is offline   Reply With Quote
Old 07-04-2017, 07:29 PM   #10
Rik
Drives: 2017 ZL1
Push the trunk down till it clicks then open using remote.
Rik is offline   Reply With Quote
