Old 07-03-2017, 11:23 PM   #1
MXSG
MXSG's Avatar
Drives: 2016 1SS
Loud Squeaking/Scraping Sound from Rear End?
Earlier today I noticed a squeaking metal-on-metal sound coming from the rear of the car. It happens at all speeds and seems to be linked to wheel rotation. It occurs regardless of the brakes being applied or not. Volume is not consistent but it's audible even with the windows up.
Car is a 1SS with 2,200 miles with aftermarket wheels and an exhaust, no other mods. Any ideas before I make an appointment to take it in?
MXSG is offline   Reply With Quote
Old 07-03-2017, 11:24 PM   #2
n813ca
Drives: 2106 SS
It's the normal bad issue
Sent from my SM-G935V using Tapatalk
n813ca is offline   Reply With Quote
Old 07-04-2017, 12:19 AM   #3
pieceofchum
Drives: 2016 1SS Auto Dual Mode
I am about to buy a 2016 Camaro 1SS and I noticed on the Carfax that the car was brought in a bunch of times where the dealer checked the rear differential and axle which concerns me. I didn't notice anything during my test drive but that doesn't mean anything. So what is the "Normal Bad Issue"? How can I check if the car has a problem with the rear diff?
pieceofchum is offline   Reply With Quote
Old 07-04-2017, 07:50 AM   #4
Codester5
Drives: 2016 Camaro SS
Have differential fluid changed and get dealership to pay for it. I did by threatening the survey when they told me no. I did it 6 months ago and it completely fixed it. I drove it 8 months with that noise and feeling. Even if they say its normal its not right. It can and should be fixed with thefluid change. It'll clear out metal shavings in it that are causing the grind. I credit this forums users for the advice back then and i appreciate you all. We are all a family
Codester5 is offline   Reply With Quote
Old 07-05-2017, 08:45 AM   #5
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
You say you have aftermarket wheels....correct backspace and offset??? what size tires did you put on?? If the tires are taller and wider than stock you're probably gonna have to relocate a wiring connector behind the rear fender liner (driver side). There's several threads on the subject.
nancygrl is offline   Reply With Quote
Old 07-05-2017, 10:13 AM   #6
MXSG
MXSG's Avatar
Drives: 2016 1SS
Thanks for the responses. The noise went away yesterday, but if it comes back I'll have the dealer change the differential fluid since that seems to be a common problem based on everything I've been reading.
Wheels and tires should be OK as I have the MRR 1LE replicas that a lot of people are running - I did check my wiring harness again and still no rubbing.
Old 12-02-2017, 09:35 PM   #7
Nightfall6
Drives: 2017 1lt RS Nightfall Gray
I have the same problem and it does sound like metal-on-metal grinding, and its so damn loud and embarrassing. Happens when accelerating past 1200 rpms.
Nightfall6 is offline   Reply With Quote
Old 12-03-2017, 12:05 PM   #8
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
Isn't this the positraction clutches that after a few turns they get fresh gear oil in between them and quiet down?
Magnum922 is offline   Reply With Quote
Old 12-03-2017, 04:18 PM   #9
NJerzeeSS
NJerzeeSS's Avatar
Drives: 18 2SS Coupe/Hyperblue/Jet Black/A8
I have the same issue
2018 2SS Coupe/Hyper Blue/Jet Black/A8
2019 AMG E63S 4Matic Wagon
2010 G37XS/Sedan/FI Exhaust/Hotchkis Sways
NJerzeeSS is offline   Reply With Quote
Old 12-12-2017, 06:03 PM   #10
Nightfall6
Turns out the problem I had was an exhaust issue. Theres a bolt on the underside of the resonator and there was a crack there that somehow resonated along with exhaust once it gets up to a certain temp.
Old 12-12-2017, 10:21 PM   #11
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
TSB Number:
16-NA-399
NHTSA Number:
10116609
TSB Date:
February 28, 2017
Date Added to File:
August 30, 2017
Failing Component:
Wheels:Lugs/Nuts/Bolts
Summary:
This bulletin advises the service technician of new longer bolts and lock washers required to be installed during repairs that require the half shaft bolts to be removed or replaced.
Originally Posted by Marty McFlew View Post
Who has had the this Axle failure?
#16-NA-399: Information on Replacing Half Shaft Fasteners with Revised Parts - (Dec 19, 2016)
Subject:Information on Replacing Half Shaft Fasteners with Revised Parts
CadillacATS-V20162017LF3, LF4, LT1, LT4CTS-V20152017ChevroletCamaro20162017
Involved Region or CountryNorth America and N.A. Export RegionsConditionThe technician may need to perform a repair that requires the half shaft bolts to be removed.
Information
This bulletin advises the Service Technician of new longer bolts and lock washers required to be installed during any repair that requires the half shaft bolts to be removed or replaced.
  • Three retainer assemblies required per half-shaft.
    • Each retainer (3) requires 2 bolts (1) and 2 washers (2) to make a retainer assembly.
    • Where applicable, each axle assembly uses 3 retainer assemblies per side.
    • Each repair kit contains 6 bolts and 6 washers. 1 kit for each half shaft.
    • Replacement of all axle bolts are required during repair.
Correction
If half-shaft has been separated from the differential:
  • Remove and discard only the half shaft bolts.
  • If required, clean and reuse retainers.
  • Replace the shorter bolts (1) with a new longer bolt (2) and washer.
  • Install the lock washers onto the bolts.
  • Install bolt and washer assembly into retainer.
    • Torque bolts to proper torque specifications. Refer to Fastener Specifications in SI.
Service stock half shafts may include POA bolt/retainer assemblies. These assemblies may require rework with longer fasteners.
  • The new half shaft bolts must be removed, measured and discarded if the length is incorrect.
Parts Information[COLOR=brown !important]Note: To obtain the bolts and washers, fax the form included in this bulletin to the GM Warranty Parts Center (WPC). Request WPC #816.
Use the Vehicle Identification Number (VIN), SI, and the GM Electronic Parts Catalog to determine the proper part numbers for the half shaft, if replacement is required:
Bolt/WasherWPC #8161 kit (6 bolts/6 washers)
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 12-14-2017, 09:06 PM   #12
PersonX51
PersonX51's Avatar
Drives: 2017 SS
Yes its a normal sound real positracks with clutches makes .. No real fix for it.. Other than Whale oil additive ( no longer available ) the synthetic oils just cant get rid of the noise ... nothing wrong with the Positrack otherwise
what happens is the oil drains out of the clutches when its sits.. ( like over night ).. so the first few turns you make the clutches chatter then once you have driven enough and made a few turns in both directions .. sound should diminish because they got some oil in the clutch packs...
When to worry: when it "stops" making that sound .. time for new posi clutches... I know... now your all going to have a panic attacks about not having the sound......
On a less humorous note. DON'T Worry the clutches will last a long time!!!! .....unless you do Idiot burnouts all the time... then nothing can help you .. "stupid is as stupid does" so don't be stupid.... Leave the burn-outs for Funny Car drivers. they are a waist on anything less
PersonX51 is offline   Reply With Quote
