![]() Drives: 2017 ZL1 Join Date: Jun 2017
ZL1 Waylens footage/track input
I took my car to the track Friday and got about 10 runs in. This car is so hard to launch. Best I could get was a 12.4 @ 121mph and a 2.1 60'. Last run we hooked HPTuners to data log. It shows timing being pulled as soon as we launched the car.
So after a ton of research on here and looking at Cwebsters write and post I decided to try what he was doing. Track mode, no launch control, TC off, SC on and launch at 4K RPM. 2nd run which is the video, I hit Rev limiter thinking I could make it in 3rd, cost me 5 mph. Lesson learned. I took the car back to a business park to get some practice in. It's going to take a lot more reps but I figured I'd share the videos. https://youtu.be/yTHMNi-2bIw https://youtu.be/6MF5Mtc7UG4 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
ahh looks awesome! I was bummed on my Mustang that the ODBII boost didn't show up on my WayLens. Good to know it works on the Camaro
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
Thank you Al Oppenheiser!
What's up with the G-force meter and the crackling in the audio?
#4 | |
![]() Drives: 2018 Red Hot ZL1 1LE Join Date: May 2017
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built! |
I didn't hear any crackling of the audio, I have on other videos though, I don't know where it comes from. The G-force meter is reacting to the car rocking, it doesn't help if the camera isn't perfectly square, it will read as pitch and roll......I've only had the camera since Friday so I'm still learning.
The M6 cars pull timing if you try to launch them using Launch Control, there's a few post on here about it, after I left the track and did some research I read that it's best not to use the launch control and to leave SC on and it will help. I intend on tuning the car once my pulley comes in and we can fix the timing issue in Torque Management.
#7 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Yeah, it seems to be bogging out of the hole. I like that Waylens set up.
Kindness and compassion #OthersFirst |
#8 | |
IG: 2fast2nick
#9 |
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
The manual transmission ZL1 is not hard to launch, it's next to impossible to launch. I keep telling people there is a legitimate issue with the car, but it seems a lot of people assume the car is perfect just because one guy achieved a good time by double-clutching and fooling the computer into not pulling timing.
I started this thread a while back to document an investigation into what I believe is a related cause. Feel free to skip to post #97 and read the attached summary which contains the latest information I sent to GM. http://www.camaro6.com/forums/showthread.php?t=498180 |
#10 |
![]() Drives: Bucket Join Date: May 2009
#11 | |
Of course if you have great traction, and little-to-no slip, torque management cuts the power. So basically you're screwed either way. |
#12 |
#13 |
Thanks, folks.
The Mustang had the clutch protection as well, which would, in theory, engage TC and pull timing cooperatively. So, sounds like tuning would fix this.
Built! |
#14 | |
Drives: Duramax Join Date: May 2017
Wouldn't it be nice to have a "COPO" Mode and launch like a COPO Camaro.https://youtu.be/6qItrfYVw-E |
