Old 07-01-2017, 08:32 PM   #1
whitelightning011
whitelightning011's Avatar
Drives: '16 1SS A8 w/ NPP
Installing Black Bowties
Hi all,
I saw some threads about this but I had a few questions on my own. Regarding the black bowties, is it possible to install this myself without ruining something?
The part I am looking to buy is here.
From what I understand, the front emblem is held in place by clips. Do I just pull it out? And the back emblem is apparently glued on, so do I use floss/fishing line to get that out cleanly?
Has anyone installed this particular emblem set on their vehicle? If so, was installation easy?
Thank you.
whitelightning011 is offline   Reply With Quote
Old 07-01-2017, 09:03 PM   #2
Medic726
Medic726's Avatar
Drives: 2020 Camaro convertible RS Auto
Havent used that particular set but did swap mine out. I removed the rear by just heating it up with a heat gun and pulling it off. I used a trim tool on the front emblem. Worked the right side until I could get a grip with my fingers and then just pulled it. Pretty easy to remove both
Medic726 is offline   Reply With Quote
Old 07-01-2017, 09:03 PM   #3
JDono
JDono's Avatar
Drives: 2024 ZL1 M6 Vert - Riptide Blue
Phastek installation guide
JDono is offline   Reply With Quote
Old 07-01-2017, 09:33 PM   #4
JoeCamaro444
JoeCamaro444's Avatar
Drives: 2018 2SS M6 Hot Wheels Camaro
That was pretty cool. I had no idea that the chrome outlines could be used with inserts. I thought the whole emblem would need to be replaced. Pretty clever way to do it all too, with the drilling. 😎👍🏻
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars:
2017 1SS Nightfall Gray Metallic w/A8 and NPP
1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps.
JoeCamaro444 is offline   Reply With Quote
Old 07-02-2017, 12:16 PM   #5
trboxman
Drives: 2017 2SS, M6, HBM
I would think that they'd want to drill before heat so that the glue is more compliant when you start trying to lift if vs. heat, drill/cool, lift...
trboxman is offline   Reply With Quote
Old 07-02-2017, 02:33 PM   #6
whitelightning011
See that's the thing...I don't have a heat gun nor a garage to work in. In NYC it's hard to find a place to work on your car...so I'd have to do this on the sidewalk.
Old 07-02-2017, 02:50 PM   #7
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You can do this whole thing with a couple big trim tools off Amazon for 15 bucks, some Goo gone, some fishing line and a lot of elbow grease, right at the curb. Discussed many times in the cosmetic section of the forum.
My How to from the Corvette site
http://www.stingrayforums.com/forum/...adging-c7.html
Old 07-02-2017, 04:15 PM   #8
NCSD
Drives: Nightfall, 2SS, A8, MRC, NPP,RE-71R
I did this , super easy took about 10 minutes and only about 2 dollars of plastidip. Still looks good after 8 months.
NCSD is offline   Reply With Quote
Old 07-02-2017, 04:22 PM   #9
PinHead
Drives: Duramax
Talk to the Boys at the end of the Block.....They'll show you their "Midnight Auto Parts Removal and Re-Installation Techniques."
PinHead is offline   Reply With Quote
Old 07-04-2017, 02:18 AM   #10
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
well you can do what my dealer did and use a plastic pry bar to pry the rear off. onLy had to repaint the trunk lid.
they gave it to a kid who had no idea how to remove a badge.
Old 07-04-2017, 09:22 AM   #11
camaromike77
camaromike77's Avatar
Drives: S O L D
..... I'd be looking for a new Dealer.....
Club F1FTY
Old 07-04-2017, 01:00 PM   #12
JCunningham
Drives: 2017 2SS M6
had to repaint the hood too do to bird shit ate the clear coat
black emblem installation
