Old 07-01-2017, 12:56 PM   #1
Getinthur
Drives: 2017 ZL1
Line Lock/Emergency Brake
So last night I went to the local track, I got about 12 runs in. Half of those I used the line lock feature and about 7 seconds into doing a burnout, I go to cancel and roll out of the burnout and the emergency brake engages. Has anyone else had this problem before?
Getinthur is offline   Reply With Quote
Old 07-01-2017, 04:15 PM   #2
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Yep. It would seem to happen if I messed up the "release" before the timer ran out. For some reason pressing both buttons on the wheel has only worked for me once out of about five times. The one time it worked and I rolled out of the burn out, the brake e-brake didn't end up engaged.
I just assumed it was a safety mechanism to keep the car from turning in to a Mustang and mowing down a crowd.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 07-01-2017, 04:39 PM   #3
rtm_tinman
rtm_tinman's Avatar
Drives: 2017 camaro ZL1 Red Hot M6
It has to do with touching the break when in line lock. If you let the timer run out it will automatically let you do a roll out not put the breaks on.
rtm_tinman is offline   Reply With Quote
Old 06-23-2019, 06:51 PM   #4
Ripper1
Drives: 17 ZL1 convertible
This happened to me today as well. I have never had it happen in past track visits. Has anyone identifies the cause?
Ripper1 is offline   Reply With Quote
Old 06-23-2019, 08:25 PM   #5
Markoz28
Drives: 18 ZL1 nightfall grey A10
Yep, normally boils down to user error. Make sure not to touch the brakes and push both buttons to release the line lock.
Markoz28 is offline   Reply With Quote
