![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Just a heads up on the fogging windshield issue
Took my 17 SS into the dealer for this issue. The TSB doesn't provide the dealer with anything more than the direction of what to look for, there is no specific tool as the dealer has to make their own to try and reach the foam piece in the HVAC box.
Well the windshield has to come out just to try that repair. If that doesn't work just a heads up, the car has to almost come completely apart. Both doors have to come out, both front seats and the console come out, then the entire dash has to come out in order to get to the HVAC box and fix it. I decided to pass on it at this time, the job only pays 6hrs of labor. That is going to force a tech to rush and in turn steps and pieces will get hurried. Cant believe GM isn't paying anything more than that for as much work as it will require. |
#2 | |
![]() Drives: 6th. Gen ZL1 Join Date: Jan 2017
Ouch, that is ridiculous. I was out as soon as I found out that the fix required them to remove the windshield. A tech doing the rest of that? No way. Thank you for sharing
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
![]() Drives: 2017 2lt rs Join Date: May 2017
1970 - 1987 worked as a tech in a GM dealer. Some jobs paid bare minimum.other operations paid really good. Atech will not re &re a windshield ,this will be sublet out to a glass company. With the windshield removed and the defroster grill removed,an inspection camera can be inserted thru the duct to spot the foam.Then the tech would insert a flex grabber claw to remove the foam.most techs would probably not want to invest in a good boroscope.A well equipped dealer should have one of these in their Kent Moore tool room.mine has done this once will wait to see what happens when it gets more humid.Found it inconvenient for about 30 seconds
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
![]() Drives: 2106 SS Join Date: Aug 2016
Sadly this problem is very dangerous where it is humid. Maybe it is time for me to move on.....
Sent from my SM-G935V using Tapatalk |
#7 |
Thank you for the heads up though. I just wished GM would wake up
#8 | |
Mine was in for an unrelated issue earlier this week and I asked them to fix this since I live in FL and on humid mornings this fog takes up 1/3 of the windshield smack-dab in the center. Rather than following the advice of the TSB, my dealer "reprogrammed the HVAC". I rode home from the dealership this evening on AUTO with temp set at the lowest possible setting in a sweat pool because of this adjustment - 20 minutes of absolute miserableness. Needless to say, it's going back to the dealer tomorrow to reprogram the HVAC back to normal. All this to say, tell them not to screw with the HVAC programming at all costs. |
#9 |
Thank you miaterbill
#10 |
Misterbill77
#11 |
My dealer didn't have the camera or the claw, they were told by GM TAC to make their own tool or find a claw, they told me that GM has not specified any specific tools other than how the process should work involving removing the windshield.
#12 |
One El E
Drives: 2022 2SS 1LE M6 Join Date: May 2016
Not sure about what you were told but today I visited the dealership to set an appointment to fix this issue. The service writer pulled up the bulletin I provided and she says it is only a 2 hour job. I specifically asked about pulling the windshield and she said it doesn't direct them to do that. The only thing they remove is the upper dash is what she relayed to me.
AND, only cars cars built between certain dates are eligible for this fix. I apologize for not asking what specific dates. Hmmmm....
Retired USCG
#13 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Some Dealers are just..... grrrrr.
Some will make your day. Others will give you orange juice with a bag of popcorn and tell you that's how you fill the tank. |
#14 | |
![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
Fogging windshield
