![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Aug 2016
Weight Reduction
I figured I would start a thread on weight reduction for the ZL1. Minor things to start.
Rear seat (lower portion) 11.6 lbs Rear seat (upper portion) 17.8 lbs Rear seat belts and all hardware 4.6 lbs Total of 34 lbs. Shraders rear seat delete kit weighs in at 14 lbs. Netting you 20 lbs in weight savings. I was thinking about making my own lightweight version or just simply carpeting both areas of rear seat... roughly 330 bucks is kinda steep for a seat delete kit in my opinion. who knows I might end up just buying it... I figured i would do this because nobody will be in the back seat anyway and its less maintenance with cleaning... It would be great if people will chime in about their catback exhausts, intakes, racing batteries, wheels, etc, etc. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
I can do that when I have a little more time. I just packaged them up and put them in my basement. As far as thickness its roughly 6 inches at its thickest point. Upper cushion is a little thinner.
ATI did a full kooks exhaust and lost 24lbs.
"97 lbs for complete exhaust system top to tail. 12 lbs each for DS and PS Manifold. 121 lbs complete Factory system" Braille Battery's save weight. I swapped out my 2013 ZL1 battery with a Braille battery and saved like 20 plus pounds. This battery in my 2017 seems smaller so not sure what you would save there.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
#5 | |
I don't have a Z but I plan the same thing in my 1ss. Need to lighten up a little since I put the SC on it. Drag Pack will save you a 100 lbs if your going to drag race it. That was 3 tenths in track times and a few mph. .
#7 |
I removed the Air pump pack in the trunk for starters.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Should definitely be in the 10's now!!
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#9 |
Bring It
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
#10 |
![]() ![]() ![]() Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Take a look at this thread, lots of info/ideas:
http://www.camaro6.com/forums/showthread.php?t=474068 |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
I guess I could take out the 2 cases of beer in the trunk.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
#12 |
that's the goal
Plus I lost 115 lbs over the last year so there's that too. ![]() 3 pounds 14 oz and that doesn't include the hook. |
#13 | |
![]() Drives: 2018 ZL1 Join Date: May 2016
#14 |
I found 20 of it if you want it back
