Old 06-29-2017, 10:42 AM   #1
CarFlow1
Drives: 2017 ZL1 A10 (Summit White)
Heads Up Display
Has anyone experienced any issues with their Heads Up Display? Suddenly, mine isn't appearing as it usually would. Reaching out to community to verify, not sure if there's a quick fix that I'm unaware of.
CarFlow1 is offline   Reply With Quote
Old 06-29-2017, 10:58 AM   #2
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Did you readjust your seat maybe, now out of range?
someone touch the brightness or move it too high or low?
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 06-29-2017, 11:02 AM   #3
Smuuth
Smuuth's Avatar
Drives: 2017 Hyper Blue Metallic ZL1
HUD CONTROLS:
LEFT —
Press down or lift up to center the HUD image. The HUD image can only be adjusted up and down, not side to side.
CENTER —
Press to select the display view. Each press will change the display view.
RIGHT —
Lift up and hold to brighten the display. Press down and hold to dim the display. Hold down to turn the display off.
The HUD image will automatically dim and brighten to compensate for outside lighting. The HUD brightness control can also be adjusted as needed.
The HUD image can temporarily light up depending on the angle and position of the sunlight on the HUD display. This is normal.
Polarized sunglasses could make the HUD image harder to see.
By the way, it's "Head Up Display," not "Heads Up Display."
Smuuth is offline   Reply With Quote
Old 06-29-2017, 11:04 AM   #4
CarFlow1
Good points, I did adjust the interior lighting last week (the knob directly to the left of the steering wheel) the highest setting will turn the interior lights on. However, even after turning the knob down (interior lights are off but well lit) the display isn't showing up.
Seating position isn't that high either to be out of range
Old 06-29-2017, 11:08 AM   #5
CarFlow1
Originally Posted by Smuuth View Post
HUD CONTROLS:
LEFT —
CENTER —
RIGHT —
Head up or Heads up...you knew what I was referring to.
Old 06-29-2017, 11:12 AM   #6
KenB925
Drives: Raptor
yeah, check your adjustment, it really doesn't take much for it to disappear entirely, I have it in the wifes escalade and I have to adjust it to find it every time I get in.
KenB925 is offline   Reply With Quote
Old 06-29-2017, 03:51 PM   #7
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
I've noticed that certain sunglasses make mine completely disappear. When I wear them I have to turn the intensity all the way up or I can't see it. Just a thought too.
Inspector 17 is offline   Reply With Quote
Old 06-29-2017, 04:58 PM   #8
addyb0y5
Proud Camaro owner
addyb0y5's Avatar
Drives: 2019 Camaro ZL1 1LE
Any polarized sunglasses - to be specific. Regular ones are just fine. :-)
2019 ZL1-1LE -Crush
2020 Ram 1500 Limited (DD)
2018 Volvo S90 T6 AWD (DD) (Sold)
2018 Focus RS (Sold)
2013 ORANGE/BLACK 2SS (Sold)
2015 Acura TLX V6 SH-AWD (DD) (Sold)
2015 Honda CBR600RR (DD) (Sold)
addyb0y5 is offline   Reply With Quote
Old 06-29-2017, 07:03 PM   #9
CarFlow1
Cool, I got it fixed there is a switch that is used to dim and to adjust its height.
Old 06-29-2017, 08:24 PM   #10
bucknut2006
Drives: 2017 ZL1 A10, 2015 C7 Z51
The newer HUDs are much better with polarized sunglasses. I could barely see the older monotone ones, but the color ones in the C7 Corvette and 6th Gen are fine, just a little less visible.
2017 Camaro ZL1 - Nightfall Gray Metallic - A10 - Roto-Fab intake
bucknut2006 is offline   Reply With Quote
Old 09-05-2019, 01:18 PM   #11
2017camaro
Drives: 2017 camaro
Can you zoom in or out on the head up dispay?
2017camaro is offline   Reply With Quote
Old 09-05-2019, 05:31 PM   #12
Gary H
Drives: Camaro ZL1
No
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving...
Gary H is offline   Reply With Quote
Old 09-05-2019, 05:49 PM   #13
NeverDie
Drives: 2017 Camaro SS 1LE
Yes many brands of polarized sunglasses will do this (depends on how they apply the filter). I live in Arizona, so I'm pretty much always wearing sunglasses... I completely forgot it existed until I drove it at a night time track event a few weeks back.
NeverDie is offline   Reply With Quote
Old 09-05-2019, 07:25 PM   #14
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
When I first got the car first few days of getting used to it, sometimes I had a green HUD, sometimes white. Took me awhile to figure out my dark tinted but not green RX sunglasses was the culprit.
Paintslinger16 is offline   Reply With Quote
